Brush Hog chain guard
/ Brush Hog chain guard #3
Made mine from tractor-trailer mud-flaps ( cut it on a band-saw ), used angle iron, fender washers, bolted-on and spaced it a couple of inches away to allow for high grass to exit...been using it for 6yrs. , still solid, works great, way cheaper than the chain set-up/cost and durable...chopped-up plenty of rocks and no problems
/ Brush Hog chain guard #4
how can i fab one myself????
Welcome to TBN!
If you can get some "conveyor belt" like they use in the coalmines that works great.
When I worked in the mines they let employees have some of the old belt... I made a guard for mine and it works great.
If you use conveyor belt, then you need to cut it so the belt won't fold back under the bush-hog when pulling it, because the blades will cut into it.
/ Brush Hog chain guard #6
I thought about telling you where you could go to find no cost mudflaps, but your profile doesn't list the country, state or area that you reside, so I can't begin to list all of the places you can find them. Truckers learn where we leave used mudflaps.
Welcome to TBN
David from jax
/ Brush Hog chain guard #7
Welcome to TBN loweman!! If you fill out your profile....we can know allot more about you and the kind of cutter you want to put a chain guard onto.
I built front one for my King Kutter (cause I can see the spinning blade tips from the tractor seat :eek:).....and had to position it about 6" forward of the deck so the chains wont drape into the blades.
I am considering adding a rear guard this winter. Do a search for "chain guards" and you will find lots of pics and advice on the topic.
/ Brush Hog chain guard #8
I built one out of truck mudflaps and some angle iron.. works great.
soundguy
/ Brush Hog chain guard #9
I wanted to stop the dust from blowing on me when mowing on dry days more then anything else, so I cut an old tire in half and bolted it to the front of my mower deck. The angle on it allows it to slide over the ground when I have it low, but the shape of the tire catches the dust and sends it off to the side. Nothing gets through that tire!!!
Eddie
/ Brush Hog chain guard #10
I used some conveyor belt from our plant to make my guard, still have to make one for the back. I may have to move the front guard out some to miss the blades but we will see, I guess it will self clearance it self. I have about 75 feet of 24" of belting to play with so I can get it right.
/ Brush Hog chain guard #11
I made one similar.. I just offset it a lil forward.. works great at keeping dust and debri contained.
good job
soundguy
/ Brush Hog chain guard #12
I welded chain to 5 feet of angle then bolted it on. I do hit rocks along driveways... It seems to work fine.
The angle extends the chain far enough away to clear the blade.
Have some type of guard, it couldn't hurt.
Happy trails,
Dave
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Bucket (A64194)
Pemberton Inc...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
2005 MACK CHN613 (A65643)
2005 MACK CHN613...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
