Brush hog advice
/ Brush hog advice #81
LD1...that is exactly what I was trying to say!
For the record, what you actually said - and what started this unfortunate exchange in the first place - was "The cutters take less HP to run than the finish belly mower...".
I admitted my mistake....
//greg//
/ Brush hog advice #82
i can't imaging subjecting a finish mower to tall grass.. just wasn't designed for it.. it's abusive..
soundguy
I think if the initial cut is at the mower's highest setting, then a follow up cut to the desired finish height...he should be OK. His risk, of course...
/ Brush hog advice #83
it will work, but just ain't the right tool for the job.
I can take a pair of toenail clippers and head out into my pasture and EVENTUALLY get it under controll
there's a fair amount of abuse involved though... :)
/ Brush hog advice #84
//greg//
Yeah...the original statement was as Greg wrote...and if someone asks me a question (or comments) about the use of a powered implement, I always consider usage at full capacity in my answer.
In this case, the quoted comment was incorrect for general use of rotary cutters...
Another recent thread (about chippers) asked about using a chipper that required a minimum 30 PTO HP to operate. The poster's tractor had 21 PTO HP and he's not going to get the full capacity of that chipper...but if he's just chipping 2-4 inch stuff, he may be quite satisfied.
/ Brush hog advice #85
Yeah...true. Might be the OP can only afford one implement...the mower, or the cutter.
Now that reminds me of scrubbing the deck (in the head) with a toothbrush (Navy bootcamp)...and yes, that was abusive!
/ Brush hog advice #86
//greg//
I still agree with ruffdog on this one. But I see your point as well.
If you are mowing your yard, knocking 1.5" off of the top of your plush lawn, then yes, that takes less HP per foot than using a RC and cutting up a field with 30-40" of thick grass. That I think we can agree on.
I took from the context of ruffdogs post (in which you quoted a peice of) that he is mowing an area once ever few weeks. Not as often as a lawn, but still often. And he mentions that his RC takes less HP (boggs down less) and he can travel faster. But at the sacrifice of not quite as clean of a cut.
And this is exactally what I have been talking about. Fields that only get cut once every 2-3 weeks. It is at the upper end of a RFM's capacity, and requires a really slow speed to keep from stalling, but wouldnt even break a sweat for a RC.
The only reason a RC and a RFM are "rated" different by MFG's is because they expect you to be able to go through some really thick stuff with the RC. But are only expecting you to mow a lawn with a RFM. So this comparison is really a moot point, but go mow 36" of thick grass with a RFM, and then do it with a RC of the same size and see which one uses more HP.
No mistakes to admitt IMO
/ Brush hog advice #87
NEVER being one to argue myself, ( ;) ) and NEVER being one to antagonize folks who ARE arguing/debating an issue ( ;) ) , let just toss this gem into the strum.....
Not EVERY rough cut mower is the same. Not EVERY finish mower is the same. I've seen a few rough cut mowers with sharpened blades that'll outperform many a finish mower for manicuring a "lawn". I've seen the occasional finish mower that'll handle tall, thick grass better than some rough cut mowers............... just sayin'......There are no "across the board absolutes"......
Arguing a point with such a gray area in the middle is just about meaningless without SPECIFIC brands/models and their particular characteristics. Continuing to argue just for the sake of arguing........well.......That speaks volumes too....
/ Brush hog advice #88
good call.
I actually own a finish mower that is beefy enough to rough cut. the blades are 3/8", and on a blade carrier, and can swing free ( like a rough mower ) and just like ones I had on a 4' rotary mower.. vs fixed 'lawnmower' style blades.. etc.
deck / side height on a rotary cutter really determines alot on how well it finish cuts. the old KK mowers from 10-13 us ago had really short sides and if you had a good 3pt or limit chains.. you could cut down to 2" by adjusting tail wheel. Newer ones and howse units I've seen ( and have ), have a much taller deck.. more like 6", preventing you from cutting much lower than 4-5" etc.
soundguy
/ Brush hog advice
I'm the OP, and I never said nuttin bout no finish mower:D
You guys veered off the path to have your own debate a while ago:confused2:
Best I can tell, somthing to do with abuse, and toenail clippers:laughing:
Getting back to my favorite subject........ME! :), I started work on the brush hog, and shot more video, but youtube is giving me lots of upload failures lately.
Found out it looks like either my stump jumper, or blade carrier is bent. Think it is worth going through the trouble of trying to remove, and straighten it?
/ Brush hog advice
Got another video on the 305 to upload:
[ame=http://www.youtube.com/watch?v=3ypNNvLIzQg]Bush hog 305 Part 2 - YouTube[/ame]
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
(INOP) 2015 POLARIS SPORTSMAN ACE 570 (A59823)
(INOP) 2015...
CFG Industry 680 QA Hydraulic Breaker (A60463)
CFG Industry 680...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
2011 Chevrolet Cruze Passenger Car, VIN # 1G1PK5S94B7295110 (A61165)
2011 Chevrolet...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
