Brush hog advice
/ Brush hog advice #101
How hard is it to weld with an oxygen/acetelyne or propolyne torch?
Because I wish I had a torch to help me scrap my backhoe. Some pins are stuck, and some pieces are too big to move, and need to be cut up.
you can only weld with oxy/acetelyne torch. Not propane. But you can braze with a propane torch.
/ Brush hog advice #102
LD1...steve did not mean propane. It is polypropylene.
Here is an article describing the difference between propylene and acetylene.
Oxy-Fuel Cutting with Propylene
The shop worked at switched over to propylene years ago. There is a learning curve but it does run much cleaner.:confused2:
/ Brush hog advice #103
It appears I mis-read his post:confused2:
But thanks for the link. It looks like you still cannot gas weld with it though. Leaving only oxy/acet for that.
/ Brush hog advice
Yup, I really slaughtered the spelling on that one:ashamed:
Good link. I see why guys say it cuts faster.
/ Brush hog advice
That's just stupid IMO.
I guess they figure it makes the tractor more desireable to a potential buyer.
Problem is, if the buyer has no interest in a Brush hog, or post hole digger, they will attach little value to them when formulating an offer to buy.
Another reason might be the seller is still working the tractor while it is for sale, and if he sells the impliments first, would have nothing to use. One seller told me "spring was coming" and that if he did not sell the package by then, he'd use it then.
There are occasions where one might not want to sell any impliments untill the tractor is sold. I have a few impliments made for my Earthmaster, and although the tractor is rare, I've seen genuine impliments for them go for more $$ than the tractor! If I were selling mine, I'd would not sell the impliments untill I had the tractor sold, and the buyer would get first shot at the impliments.
Gotta get back to trying to get this blade carrier off! :mad:
Steve W.
/ Brush hog advice #107
I dont think it is stupid.
Sure, the seller probabally knows he will get less $$ total, but less hassle in return.
If he sells JUST the tractor and then tries to sell the BH, a potential buyer cannot see it operate, and he does not have a way to load it. So a buyer would have to go to the trouble of bringing his own tractor. And then the buyer knows the seller probabally wont negotiate much, since you went to the trouble of bringing a tractor to test and load. Again, just a lot of hassle.
And if he sells the bushhog first, the tractor is probabally usless to him.
Odds are, it is probabally just a cheap BH to sweeten the deal on the tractor.
The reasons are many why someone doesnt seperate equipment. To each his own. Both methods of selling work, so it obviously isnt too stupid.
/ Brush hog advice #108
IMHO.. gas welding is too time consuming and costly, when an arc welder is faster and easier to use.
I use a O/A torch for cutting.
propane? that's good to solder or cook hotdogs...
soundguy
/ Brush hog advice #109
soundguy
I have to agree with Soundguy, I always use my ARC or even my little mig to weld, my O/A is 90% for heating stuff to take it apart and the other 10% to cut stuff that is too think for the plasma.
/ Brush hog advice #110
yep.. oa for cutting heatin, and lighting grease fires in hubs cutting races out... :)
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
404 (A52706)
404 (A52706)
1990 TRAIL MASTER  TRANSPORT TRAILER (A60736)
1990 TRAIL MASTER...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
2014 Dodge Grand Caravan Van (A59231)
2014 Dodge Grand...
