Brush guard that works
/ Brush guard that works #1
wichiwichi
Farmersville, TX
Kubota B7500DT,June 2000
I have modified the factory brush guard so that it will actually stop most brush. Added a 2" id pipe filled with lead and expanded metal. Also in the picture is a weight made of square tubing and filled with lead. Between the 2 this gives me about 160lbs and also allows use with FEL on or off. Neither interferes with operation.
/ Brush guard that works #2
wichiwichi,
Thats a great looking grill guard and certainly looks like it will do the job nicely.
/ Brush guard that works #6
I did something very similar (minus the weights) and have already saved my grill from errant branches a couple of times. Mine's painted orange, but your welds look better. /w3tcompact/icons/smile.gif This is something Kubota ought to offer as standard equipment, IMO
Pete
/ Brush guard that works #7
Where did you get the lead? I would like to make some front end weights
Most tire shops will give you their used wheel weights.
/ Brush guard that works #9
Gads!! I LOVE expanded metal!!
If ya can't do it with expanded metal and/or Duct tape...just ain't worth doin'!!
Nice job..very professional looking!
/ Brush guard that works #10
If you decide to use wheel weights, and melt them down to fill a tube or whatever, be very careful not to breathe the vapors. Sounds elementary, but I got sick for a long time as a result of melting lead wheel weights to make ingots to put in the bow of my boat. I thought I was being careful, turned out I wasn't. So stay outside and upwind!
/ Brush guard that works #11
Don't forget Unistrut!
/ Brush guard that works #12
Look in the yellow pages under "Glass Stained and Leaded". Us people that make stained glass windows for a living usually have a ton or so to get rid of after a few years of work. It is easily recycled but unless you have a fork truck it is not so easy to move a barrel full it. Makes great wheel weights for the garden tractor. Make a plaster casting of the wheel, melt and pour in a DRY mould. Make sure you allow for the bolt holes because lead is not easily drilled.
And yes be careful when handling and melting. Dust from old oxidized lead is VERY easy to inhale. It is easy to melt in a cast iron ladle. The melting point is 621.5 ーF. Please do not do this indoors or with children present. Lead is a dangerous metal but common sense when working with and handling this metal is not a problem. Wash your hands well when finished and clothing should be washed separately from other laundry. Please handle with care and keep children away from lead.
Jim
/ Brush guard that works #13
Did you say you leave the weight bar on while using the FEL? Seems like a good way to increase wear, decrease working capacity, etc while the loader is on.
David from jax
/ Brush guard that works #14
Perferated metal is nice too. It is a thin metal plate, with holes drilled ( punched? laser cut ) all over it.
soundguy
/ Brush guard that works #15
I'm curious as to what you mean about lead being difficult to drill?
I've drilled lead ingots to make bolt thru weights.
other than the metal being a tad soft?? i don't see the difficulty.
A center punch in the right area.. then steady down pressure and moderate speed... a bit of cutting oil.. really.. same setup fro drillny any metal...
I didn't see a problem???
I was only drilling 1" 1.5" and maybee 2" thick ingots..
Soundguy
Jim
/ Brush guard that works #17
Danno1 said:
It's very soft and it grabs the drill bit.
Might be the drill speed is too high? Maybe as the lead approaches melt point while drilling it glues onto the bit and begins to build up. Before you know it - no more drilling.
Turn the bit as slowly as possible, 50 -75 rpm probably would be good. A little oil as Soundguy likes and..........holes.
/ Brush guard that works #18
Soundguy
It is the thick pieces that are a problem. Just an inch or two not bad -but try six or eight inches .
/ Brush guard that works #19
Oil usage and low speed will really help with galling and sticking.. It ain't like drilling wood for sure...
Soundguy
/ Brush guard that works #20
i filled tubes with lead shot then welded the ends shut alot easier and less hazards
213066 (A64276)
213066 (A64276)
2012 Toro Z Master Professional 72in Zero Turn Mower (A61572)
2012 Toro Z Master...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2016 Mercedes-Benz 300SLK Coupe (A61574)
2016 Mercedes-Benz...
2025 Future FT-46 Hydraulic Drum Mulcher Skid Steer Attachment (A61572)
2025 Future FT-46...
