Brush clearing down steep hill, need advice!
   / Brush clearing down steep hill, need advice! #11
Silly me. I have so much stuff, I forgot. This replaced the walk behind. Has a stump cutter mounted, but shows that it's not affraid to climb!
We Steiner guys love little projects for our Steiners. Find a guy with a brush mower and hire him.
   / Brush clearing down steep hill, need advice! #12
We Steiner/Ventrac guys love little projects for our Steiners. I sort of made a rough cut mower with an old beat up 48" deck. Find a guy with a brush mower and hire him.
I got duals after this, DSC03187.JPGshown with a 60" side discharge deck. I would use the duals in very steep terrain.
   / Brush clearing down steep hill, need advice! #13
I LOVE MINE!!:thumbsup: you should have sent it my way;)
Looks like the DR I couldn't get rid of fast enough. lol Cursed every time a wheel went into a rut or had to roll over a stone/branch!
Also, it had a hard time cutting Burdocs (sp?) even with the heaviest line available.
   / Brush clearing down steep hill, need advice! #14
Anyway, I have a steep hillside
I tried backing the tractor down the hill and mowing it down only to make it 10 ft before the slope changed a bit and got too risky.
What would you recommend in my situation? TIA
It's just so steep
How steep? Angle? Elevation change?
How deep? Distance from top to bottom?
   / Brush clearing down steep hill, need advice! #15
New to the forum, just acquired 10 acres and a new L2501- love it all so far!
Anyway, I have a steep hillside along one side of the property that is covered in blackberries and runs down to a nice creek that I'd like to access. So far I've only found one potential path down for machinery and it is THICK with blackberries and other brush. I tried backing the tractor down the hill and mowing it down only to make it 10 ft before the slope changed a bit and got too risky. Even then, I had trouble getting back up the hill with tractor due to traction issues.
What kind of equipment is out there that can be used on steep terrain to decimate brush and blackberries? I'd really like to start with just cutting a path into it so I can get a sense of what's even down there, doesn't have to be super wide at this point. Also, I'm leery of spraying much due to proximity to the creek so herbicides are out for the moment.
Are you in California? If so just torch it!
Great question. Probably a 50' elevation change over 40 yards. No idea on actual angle, the other issue is that the slope is not straight down, it kinda varies side to side a bit in places so it makes tractor work super sketchy.
Oregon, and I have been burning it bit by bit down with cardboard but the slope goes down behind my barn at a point so can only do that so long.
   / Brush clearing down steep hill, need advice! #18
^^I agree^^ Until I know what is on the steep slope with a creek at the bottom, I would use the brush head to clean a path. A simple rock, log, or hole could spell disaster for a tractor.
   / Brush clearing down steep hill, need advice! #19
I live in the mountains of North Carolina. I own an old Gravely 2 wheel walk-behind tractor and a Kubota L3301. But many of my slopes are too steep and rocky for a machine. I too have many blackberries. String trimmers with saw blades scare me. I use a rechargeable hedge trimmers for the blackberries. It is labor intensive, and sometimes bloody; but works best for me.
Jack
   / Brush clearing down steep hill, need advice! #20
I have the same situation, including a bunch of willows which make excellent ladders for the blackberries. It is a never ending job to keep a path cleared. The tools I use vary depending upon how long I've let things go. I used to do a lot of the mowing with my tractor. However, it is very risky, even with 4WD, and excellent traction.
What works best for me once I've done some hand pruning, and using my EGO hedge trimmer, https://www.homedepot.com/p/EGO-20-...attery-and-210-Watt-Charger-MHT2001/308672042 is my trusty, all-terrain, DR field and brush mower. Now days you will pay a premium for one, and they are very unwieldy. Mine is an older, very reliable model with traction control, 4 forward gears, and 1 reverse. It's practically impossible to get stuck of find anything within reason, (1"-2") it can't handle. Look for the one with the 12.5 HP Tecumseh engine if you can find one used.
The key is, steady and slow goes far in a day.
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
Golf Cart (A55787)
Golf Cart (A55787)
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2008 BMW 535xi AWD Sedan (A55758)
2008 BMW 535xi AWD...
