Brown Snot in diesel fuel?
   / Brown Snot in diesel fuel? #22
surprised you'd have an algae problem given your location. (could it be gel?) lots of sound advice given here
in addition, you might change your fuel source to a high volume truck stop to reduce chances of moisture contaminated fuel. btw Optilube has a full line of products addressing moisture, algae, lubricity, & anti gel in cold weather. tho haven't run across a product that addresses all 4, regards
   / Brown Snot in diesel fuel? #23
Scrape it off and cook it up for dinner....lol
Waste of product, it goes much better on a slice of sour bread and shot of cold vodka.
   / Brown Snot in diesel fuel? #24
NO! NO! Its gotta be a sweet bread with hot vodka & brandy :giggle:
willy
I just discovered a crop of bug goo in my rearmost filter, I found I actually deleted the photo because it made me sick to look at it…lolView attachment 826914
Yes, yuck! I found this is a fairly common issue (unknown to me before). I found and used this on the SIL's. Still running good, but I'll be changing the filter (again) before winter.
   / Brown Snot in diesel fuel? #26
Don't even think about purchasing a gallon as the pint is expensive (but works). I bet the gallon costs a couple hundred bucks. Don't take much (dose) anyway so even with 3 diesels, a pint bottle lasts me a year or so.
Do keep in mind that it kills the microbes but you still need to change the filters, probably a few times because the 'skeletons' of the microbes are still in solution with the treated diesel and have to be removed.
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A51573)
1 Bridgestone...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
KSI Conveyor (A53472)
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
