Brown Snot in diesel fuel?
   / Brown Snot in diesel fuel? #22
surprised you'd have an algae problem given your location. (could it be gel?) lots of sound advice given here
in addition, you might change your fuel source to a high volume truck stop to reduce chances of moisture contaminated fuel. btw Optilube has a full line of products addressing moisture, algae, lubricity, & anti gel in cold weather. tho haven't run across a product that addresses all 4, regards
   / Brown Snot in diesel fuel? #23
Scrape it off and cook it up for dinner....lol
Waste of product, it goes much better on a slice of sour bread and shot of cold vodka.
   / Brown Snot in diesel fuel? #24
NO! NO! Its gotta be a sweet bread with hot vodka & brandy :giggle:
willy
I just discovered a crop of bug goo in my rearmost filter, I found I actually deleted the photo because it made me sick to look at it…lolView attachment 826914
Yes, yuck! I found this is a fairly common issue (unknown to me before). I found and used this on the SIL's. Still running good, but I'll be changing the filter (again) before winter.
   / Brown Snot in diesel fuel? #26
Don't even think about purchasing a gallon as the pint is expensive (but works). I bet the gallon costs a couple hundred bucks. Don't take much (dose) anyway so even with 3 diesels, a pint bottle lasts me a year or so.
Do keep in mind that it kills the microbes but you still need to change the filters, probably a few times because the 'skeletons' of the microbes are still in solution with the treated diesel and have to be removed.
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
Backhoe Attachment (A50322)
Backhoe Attachment...
Homemade Water Trailer 1100-gallon tank (A52128)
Homemade Water...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
2015 Volkswagen Jetta TDI Sedan (A50324)
2015 Volkswagen...
Root Grapple (A50322)
