Brown Snot in diesel fuel?
   / Brown Snot in diesel fuel? #22
surprised you'd have an algae problem given your location. (could it be gel?) lots of sound advice given here
in addition, you might change your fuel source to a high volume truck stop to reduce chances of moisture contaminated fuel. btw Optilube has a full line of products addressing moisture, algae, lubricity, & anti gel in cold weather. tho haven't run across a product that addresses all 4, regards
   / Brown Snot in diesel fuel? #23
Scrape it off and cook it up for dinner....lol
Waste of product, it goes much better on a slice of sour bread and shot of cold vodka.
   / Brown Snot in diesel fuel? #24
NO! NO! Its gotta be a sweet bread with hot vodka & brandy :giggle:
willy
I just discovered a crop of bug goo in my rearmost filter, I found I actually deleted the photo because it made me sick to look at it…lolView attachment 826914
Yes, yuck! I found this is a fairly common issue (unknown to me before). I found and used this on the SIL's. Still running good, but I'll be changing the filter (again) before winter.
   / Brown Snot in diesel fuel? #26
Don't even think about purchasing a gallon as the pint is expensive (but works). I bet the gallon costs a couple hundred bucks. Don't take much (dose) anyway so even with 3 diesels, a pint bottle lasts me a year or so.
Do keep in mind that it kills the microbes but you still need to change the filters, probably a few times because the 'skeletons' of the microbes are still in solution with the treated diesel and have to be removed.
2023 CATERPILLAR 259D3 SKID STEER (A51242)
2023 CATERPILLAR...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
New Holland 1431 Discbine (A50515)
New Holland 1431...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
