Broken Steering Box - B9200
/ Broken Steering Box - B9200 #1
MMH
Murrysville, PA
JD 4500
I broke the steering box on my MFWD B9200. It has manual steering and not the power steering. Started calling around to see what a replacement will cost and am getting serious sticker shock - the prices for the assembly are anywhere from $1200 to $1700. I guess that I am going to tear into the box & see if I can replace broken parts (gears/balls/etc.).
Also, I am going to start investigating what other steering boxes would fit. I found a 7300 steering box - would this work?
What about converting to power steering. Saw a couple of kits on the internet. One is designed for the 7300 so I don't know if it would work on my tractor, but I am guessing that with some minor fabrication that I can get it to work. The other kit is designed for my tractor, but is not in stock (will take 3 to 6 weeks) and it looks as if my steering gear needs to be intact.
Looking for suggestions. I need my tractor NOW and do not want to spend $1700 to get it back!
Thanks.
/ Broken Steering Box - B9200 #2
I think a number of parts from a B8200 will work. You might have more luck finding a box from one of those.
Do you have a part #?
/ Broken Steering Box - B9200 #4
The entire assembly for the B8200 is listed in my parts manual as: 66301-41100. Some cross-referencing may be in order as the # may have been superseded.
Mine does have PS but it shouldn't matter for the box itself.
Edit: I can find mine listed at: http://www.goldeneagledirect.com/
but they have no results for your #.
2006 John Deere 990 (A64126)
2006 John Deere...
JMR TREE BOOM (A61572)
2012 UTILITY VS2RA 53X102 T/A REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
