Broken Steering Box - B9200
/ Broken Steering Box - B9200 #1
MMH
Gold Member
Murrysville, PA
JD 4500
I broke the steering box on my MFWD B9200. It has manual steering and not the power steering. Started calling around to see what a replacement will cost and am getting serious sticker shock - the prices for the assembly are anywhere from $1200 to $1700. I guess that I am going to tear into the box & see if I can replace broken parts (gears/balls/etc.).
Also, I am going to start investigating what other steering boxes would fit. I found a 7300 steering box - would this work?
What about converting to power steering. Saw a couple of kits on the internet. One is designed for the 7300 so I don't know if it would work on my tractor, but I am guessing that with some minor fabrication that I can get it to work. The other kit is designed for my tractor, but is not in stock (will take 3 to 6 weeks) and it looks as if my steering gear needs to be intact.
Looking for suggestions. I need my tractor NOW and do not want to spend $1700 to get it back!
Thanks.
/ Broken Steering Box - B9200 #2
I think a number of parts from a B8200 will work. You might have more luck finding a box from one of those.
Do you have a part #?
/ Broken Steering Box - B9200 #4
The entire assembly for the B8200 is listed in my parts manual as: 66301-41100. Some cross-referencing may be in order as the # may have been superseded.
Mine does have PS but it shouldn't matter for the box itself.
Edit: I can find mine listed at: http://www.goldeneagledirect.com/
but they have no results for your #.
80003CFL (A61568)
80003CFL (A61568)
WACKER NEUSON LIGHT PLANT (A65643)
WACKER NEUSON...
NATIONAL CRANE NBT50 (A65643)
NATIONAL CRANE...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
