broken grill
/ broken grill #1
jgreen
Mid MO
Branson 2810 w/FEL, JD 40S
Hi Folks,
I purchased a used 2810 with FEL in January. Well, yesterday I was pushing some broken tree limbs on the ground so I could mow/brush cut. One limb came up between the brush guard and the grill and broke the upper grill (my parts book calls it the mask #NTD610E010A0). The local dealer (good guy) said I had to buy the entire grill assembly, not just the upper grill piece (ouch, hard on the wallet)! Does anyone know of any used parts available. I guess next time I will be a little more careful. The tractor is like new (96 hours) and I hate that it now looks like it was in a demolition derby (at least the grill).
/ broken grill #3
I had a buddy of mine jumped on my 4720 and ran a stick through the bottom
of my grill also, needless to say I was pi$$ed!
Thing was he had never been on it or ask to run it at the time...
Anyway it wasnt that bad I was able to pull it off and used some epoxy
to mend it back together along with some fiberglass strips along the back side
for added support.
I ended up with what looks like a hair line crack at the bottom.
So if ya got all the pieces try and glue it up!
Good luck
Gene
/ broken grill #4
Don't be too hard on yourself - Most of us have done the same thing
I had 60 hours on my TN before I dented the front corner of the hood in with the end of a log.
Duct Tape adds character! :)
/ broken grill #5
Our grill (3510) is in the barn in pieces. Will eventually piece it back together with epoxy and fiberglass tape but not until I have finished clearing our place - to many opportunities to put another stump root through the grill - probably right after repairing it! We did mount a set of work lights on the ROP and I have plans of tacking some expanded metal into the push bar to better protect the battery and air cleaner. However, for the next 5 or so years that yawning dark hole on the front of the tractor looks plain mean. Stumps beware!
/ broken grill #6
Same thing here with my 3820i grill. We bought a fiberglass kit the hardware, roughed up the edges, placed the fiberglass on back side. We can see the repair if you look hard.
Jim
/ broken grill #7
Any pics? Would expanded metal work as a replacement?
/ broken grill
Hi Folks,
Well, I finally got around to patching up the grill. The epoxy kit and fiberglass works if you just have some patience! Thanks for the help and advice. I don't have pics but it looks ok for the shape it was in after the tree limb. I plan to add another piece of steel on the lower part of the brush guard to try and prevent future limbs from getting to the grill.
/ broken grill #9
Glad to hear you got it fixed. Good luck and happy tractoring.
/ broken grill #10
Here's what I did with my guard a couple years back. Made a difference on protection.
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
HANDICAP PORTA POTTY (A67714)
HANDICAP PORTA...
2025 28in Forks and Frame Mini Excavator Attachment (A66734)
2025 28in Forks...
CAT 930 60" Forks (A68134)
CAT 930 60" Forks...
2025 Wolverine GB-11-72W 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A66734)
2025 Wolverine...
2013 CHEVROLET EQUINOX LT SUV (A65054)
2013 CHEVROLET...
