broken frame on PT 422
   / broken frame on PT 422 #21
There is no false bottom in the old setup. Here is a pic i took at Power trac of the new 422 set up.
   / broken frame on PT 422 #22
Here is a side view pic of the new 422 stearing cylinder set up.
   / broken frame on PT 422 #23
I see two articulation joints.
I also see what looks like a properly vented hydraulic reservoir cap. Whish our PT-425 had one of those.
   / broken frame on PT 422 #24
<font color="green"> "PT says that this is caused by scooping up dirt with the bucket and puts stress on the frame."
Now I'm worried!!! I have already done a fair amount of dirt moving...and a fair amount of going in front and semi-hard...am I to expect a problem soon!!! I HOPE NOT!! /forums/images/graemlins/confused.gif
   / broken frame on PT 422 #25
<font color="blue"> PT says that this is caused by scooping up dirt with the bucket and puts stress on the frame.
</font>
Scooping up dirt is what a bucket is for, isn't it? /forums/images/graemlins/confused.gif
   / broken frame on PT 422 #26
</font><font color="blue" class="small">( The frame is covered under warranty and if i ship the tractor to them they will fix it for free!!! )</font>
<font color="red"> I recommend taking your PT to a real WELDING shop, not a shop that also does welding! Have it properly reinforced and welded. I doubt that it would be very expensive.
Write a 'nice' letter to PT explaining what happened, and request that they pay the bill.
Even if they refuse, you will at least know that your PT has been fixed right!!
</font>
Okay- I have to admit that I have wanted to buy a lincoln 135 flux core / mig welder (115vac/20amps input) (about $550 by the time you buy flux core wire and some wire brushes). I doubt that PT will foot the bill but it may be worth a shot.
I picked up the welder at lowes last night (monday) and quickly installed a new 30 amp circuit in the subpanel in barn.
Tried out the new welder and it seems to work swell.
Here are some quick view of the excitement that followed. /forums/images/graemlins/laugh.gif
image 2
3
4
oops 5
6 -
The disassembly, prep and welding took about 3 hours this evening. (2) of the hydraulic hoses were cut when the bracket came loose so PT is 2nd day airing (??) the hoses and a steel plate to reinforce the bottom as part of the warranty.
I intend on drilling some holes in the plate and then plug welding to the old broken area and then welding the perimeter.
Then it's time to break something else I guess?
   / broken frame on PT 422 #34
</font><font color="blue" class="small">( Then it's time to break something else I guess? )</font>
I recommend something less dramatic. /forums/images/graemlins/wink.gif
   / broken frame on PT 422 #35
I like your fix, this and the added plate should hold up very well.
PJ
   / broken frame on PT 422 #36
</font><font color="blue" class="small">( I like your fix, this and the added plate should hold up very well.
PJ )</font>
<font color="red"> DITTO!! Sure beats sending it back to Tazewell!!
PS: /forums/images/graemlins/mad.gif I hate warranties! I recently bought a wall clock for $3.84. The lifetime warranty said that if it ever fails just ship it back to them and include $5.00 for S&H!!
PPS: /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif I really hate warranties! I bought a used car from a guy. He offered me a lifetime warranty. If it ever fails he said, just call him, and he'll come over and kill me!!
</font>
   / broken frame on PT 422 #37
Ba dump bump! /forums/images/graemlins/tongue.gif
Nice repair, Scarg. Now you have a welder for the cost of shipping. Better deal for you. Wish they would have picked up the welding at a local shop, though. /forums/images/graemlins/mad.gif
   / broken frame on PT 422 #38
looking at the pic of the cylinder where it goes inside some sort of boxedin enclosure , i wonder if this will be a problem when traversing uneven ground ,ie like a pinch point that could also be a problem and i also wonder why they went to the extra trouble to do that .
IMHO (well maybe not honest...) It appears that it was a cost cutting move (certainly not a change for a more robust piece of equipment) and that in order to use the one cylinder the position of the front bracket had to be moved to a stronger location. If you look closely at the fake floor on the new 422 and then at the standard 425 you can see why the fake floor was installed. I always thought that the floor was a bit high and this explains why.
However - I can't imagine that by the time they modified the frame and added the additional parts that they could have save much money /forums/images/graemlins/confused.gif
Maybe they passed enough savings on to me that i was able to purchase my welder for free??
I think that a small 115vac welder should be shipped with each unit from now on. /forums/images/graemlins/grin.gif
   / broken frame on PT 422 #40
When I was in Tazewell I know I saw the two sterring cylinders on the larger PTs but never made note that the 1 cylinder models were mounted differently... After seeing these pictures I am amazed how different the two setups are! Not only is 1 cylinder doing the work of two but bringing the "push point" in so much closer to the center must mean a lot less leverage as well. /forums/images/graemlins/confused.gif
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
CAT930K (A58214)
CAT930K (A58214)
JCB 3CX 14HFCA BACKHOE (A60429)
JCB 3CX 14HFCA...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
