broken frame on PT 422
/ broken frame on PT 422 #21
There is no false bottom in the old setup. Here is a pic i took at Power trac of the new 422 set up.
/ broken frame on PT 422 #22
Here is a side view pic of the new 422 stearing cylinder set up.
/ broken frame on PT 422 #23
I see two articulation joints.
I also see what looks like a properly vented hydraulic reservoir cap. Whish our PT-425 had one of those.
/ broken frame on PT 422 #24
<font color="green"> "PT says that this is caused by scooping up dirt with the bucket and puts stress on the frame."
Now I'm worried!!! I have already done a fair amount of dirt moving...and a fair amount of going in front and semi-hard...am I to expect a problem soon!!! I HOPE NOT!! /forums/images/graemlins/confused.gif
/ broken frame on PT 422 #25
<font color="blue"> PT says that this is caused by scooping up dirt with the bucket and puts stress on the frame.
</font>
Scooping up dirt is what a bucket is for, isn't it? /forums/images/graemlins/confused.gif
/ broken frame on PT 422 #26
</font><font color="blue" class="small">( The frame is covered under warranty and if i ship the tractor to them they will fix it for free!!! )</font>
<font color="red"> I recommend taking your PT to a real WELDING shop, not a shop that also does welding! Have it properly reinforced and welded. I doubt that it would be very expensive.
Write a 'nice' letter to PT explaining what happened, and request that they pay the bill.
Even if they refuse, you will at least know that your PT has been fixed right!!
</font>
Okay- I have to admit that I have wanted to buy a lincoln 135 flux core / mig welder (115vac/20amps input) (about $550 by the time you buy flux core wire and some wire brushes). I doubt that PT will foot the bill but it may be worth a shot.
I picked up the welder at lowes last night (monday) and quickly installed a new 30 amp circuit in the subpanel in barn.
Tried out the new welder and it seems to work swell.
Here are some quick view of the excitement that followed. /forums/images/graemlins/laugh.gif
image 2
3
4
oops 5
6 -
The disassembly, prep and welding took about 3 hours this evening. (2) of the hydraulic hoses were cut when the bracket came loose so PT is 2nd day airing (??) the hoses and a steel plate to reinforce the bottom as part of the warranty.
I intend on drilling some holes in the plate and then plug welding to the old broken area and then welding the perimeter.
Then it's time to break something else I guess?
/ broken frame on PT 422 #34
</font><font color="blue" class="small">( Then it's time to break something else I guess? )</font>
I recommend something less dramatic. /forums/images/graemlins/wink.gif
/ broken frame on PT 422 #35
I like your fix, this and the added plate should hold up very well.
PJ
/ broken frame on PT 422 #37
Ba dump bump! /forums/images/graemlins/tongue.gif
Nice repair, Scarg. Now you have a welder for the cost of shipping. Better deal for you. Wish they would have picked up the welding at a local shop, though. /forums/images/graemlins/mad.gif
/ broken frame on PT 422 #38
looking at the pic of the cylinder where it goes inside some sort of boxedin enclosure , i wonder if this will be a problem when traversing uneven ground ,ie like a pinch point that could also be a problem and i also wonder why they went to the extra trouble to do that .
IMHO (well maybe not honest...) It appears that it was a cost cutting move (certainly not a change for a more robust piece of equipment) and that in order to use the one cylinder the position of the front bracket had to be moved to a stronger location. If you look closely at the fake floor on the new 422 and then at the standard 425 you can see why the fake floor was installed. I always thought that the floor was a bit high and this explains why.
However - I can't imagine that by the time they modified the frame and added the additional parts that they could have save much money /forums/images/graemlins/confused.gif
Maybe they passed enough savings on to me that i was able to purchase my welder for free??
I think that a small 115vac welder should be shipped with each unit from now on. /forums/images/graemlins/grin.gif
/ broken frame on PT 422 #40
When I was in Tazewell I know I saw the two sterring cylinders on the larger PTs but never made note that the 1 cylinder models were mounted differently... After seeing these pictures I am amazed how different the two setups are! Not only is 1 cylinder doing the work of two but bringing the "push point" in so much closer to the center must mean a lot less leverage as well. /forums/images/graemlins/confused.gif
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
2018 ROCK SOLID CARGO EMERGENCY SHOWER TRAILER (A65643)
2018 ROCK SOLID...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2014 Ford F-150...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2017 Ford F-150 4x4 Pickup Truck (A64556)
2017 Ford F-150...
New/Unused Landhonor 78in Rock Bucket with Teeth (A65583)
New/Unused...
