broken flagpole
/ broken flagpole #1
tow653
Gasconade County,Mo
New Holland TC29,Ford Jubilee
Wind broke flagpole off at 1st section that goes into a plastic sleeve. Can wiggle it but can't pull u. Drilled hole through it,hooked chain onto 3/8",10" spike and tried a high lift jack. So far no luck. Any ideas?
/ broken flagpole #4
Oily/greasy lube might help.
/ broken flagpole #5
Just a thought because of my prior experience.
If your pole has been up for a few seasons it could very well be that water collects at the bottom of the aluminum pole & sleeve ........... when it freezes the bottom of both the pole & sleeve will "bulge and expand" creating the situation you're experiencing now.
You may have to dig it all out and start over.
/ broken flagpole #7
I suppose that it is set quite far into the ground. Is it thin enough to fashion a piece of steel to cut and split it with a sledge? Pic maybe?
/ broken flagpole #8
The kits usually have an 18" sleeve
John Deere S350 (A60462)
John Deere S350...
2019 Ford Transit 350 Police Transport Van (A61573)
2019 Ford Transit...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
