broken flagpole
/ broken flagpole #1
tow653
Gasconade County,Mo
New Holland TC29,Ford Jubilee
Wind broke flagpole off at 1st section that goes into a plastic sleeve. Can wiggle it but can't pull u. Drilled hole through it,hooked chain onto 3/8",10" spike and tried a high lift jack. So far no luck. Any ideas?
/ broken flagpole #4
Oily/greasy lube might help.
/ broken flagpole #5
Just a thought because of my prior experience.
If your pole has been up for a few seasons it could very well be that water collects at the bottom of the aluminum pole & sleeve ........... when it freezes the bottom of both the pole & sleeve will "bulge and expand" creating the situation you're experiencing now.
You may have to dig it all out and start over.
/ broken flagpole #7
I suppose that it is set quite far into the ground. Is it thin enough to fashion a piece of steel to cut and split it with a sledge? Pic maybe?
/ broken flagpole #8
The kits usually have an 18" sleeve
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2019 JOHN DEERE 333G SKID STEER (A64279)
2019 JOHN DEERE...
2022 RBR Venturi 430 High-Capacity Pneumatic Applicator (A63688)
2022 RBR Venturi...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
iDrive TDS-2010H...
