jwmorris
- Joined
- Oct 3, 2007
- Messages
- 1,190
I have removed hundreds of broken and stripped fasteners over the years but never took step by step photos and thought some welders here might pick up another “trick”. Also have used a number of methods like EZ out’s of different styles, left handed drill bits, machining and metal disintegration but my go to is a TIG welder and a nut, if they are a weldable material and not too deep.
I have successfully removed down to #2 screws and down to a #5 set screw with the method.
#1 rule of removing any fastener is to not do anything to make things worse than they already are. Very important, you drill an off center hole, then break an ez out off and I’d tell you, you should have come seen me earlier.
In this case an exhaust stud broke off in the head, a successful removal means the engine or head doesn’t need to be removed and as luck would have it the area was tight enough the fellow couldn’t get in there with a drill to mess anything up. It did however break off below flush.
Used ER70s filler to weld to the stud and bring the puddle out side of the head, to the point I can set a nut on it and creat a “bolt”.
Then weld a nut to it and put a lot of heat into it. This expands what is stuck in the part as much as possible.
As it cools I put some tension on it, not much but looking for the point it moves as it cools, then work back and forth, penetrating oil is helpful once it starts moving.
Once out, your ready to go back together.
You can see the depth of the broken stud, once removed because that’s how much weld bead vs threads there are.
Dissimilar metals make things a lot easier but with care steel on steel isn’t that difficult. It’s also useful for things that are not fasteners like the tip of this small drill bit that broke off in a part and successfully removed.
