Broken already!
   / Broken already! #31
I hate CAPS LOCK as Is spend more time having to remove caps when I accidentally hit it when I don't want to then I have to edit the caps out.... Wish there was a lock out for that key...
Dale
Getting off-topic of this thread BUT there is software available to disable or redirect the Caps-Lock function. I investigated that mod and I consider it unsafe/too difficult for me to install. My specific brand/model keyboard was handy in that I could just pry off the key leaving a gap under it. The real microswitch under the key is protected in my case by a plastic ridge/guard so I would have to go in with a pointy tool to trigger it. Perfect solution for me (though it does not look real pretty.) Keyboards can be bought with relocated "caps lock key" AND with flexible key locations. They are 6 or 8 times as expensive as normal keyboards. End of digression.
   / Broken already! #32
Just found this, ...
KeyTweak - Download
A couple of mouse clicks, Seems to work on my Dell wireless keyboard...
Back to regularly scheduled program...
Dale
   / Broken already! #33
I can't blame the dealer or AGCO/Massey for this MINOR problem. It worked fine for the first couple months. I don't yet know if it's a bad connection in the wiring, a bad gauge or dash circuit board, or something else.
All manufactured items today are a sum of the parts, and all those items are purchased from an outside company. No one builds the complete unit.
I've spent my life in trucking. One job was hauling parts for Cummins. Raw castings came from overseas, most small parts (fasteners, spacers, clips, covers, fittings, sensors, etc.etc.) came from vendors here in the U.S., and the machining was also done here, almost all of it outside Cummins plants, where they basically just assembled the parts, painted, and test fired. If one of those parts is fails, it's not really Cummins fault, it's the vendors quality control.
I would guess that the majority of failures today are in the electronic parts, and there's lots of competition in that area, mostly overseas, and cost is more important than quality to some of them.
It's also far more difficult to control quality on electronics. You can see hard parts and usually know if it's not right. Electronics may test fine with a weak internal part, but will fail when put in use.
The real issue is dealer/MFR support when issues occur. Since my issue is MINOR, I don't expect the dealer to put me at the top of the list of work. The tractor is usable, I think I will know if it overheats, and the dealer is also responsible for lots of farm equipment, which may be far more important at the time.
The tractor is currently at the dealers. I haven't heard from them, but it's only been a couple days. I mowed the lawn the day they picked it up, so I'm good for a week or so, but I told them if my grass needed mowing they better bring me something to mow with. Dealer said they would, but didn't foresee my repair taking that long.
I don't generally disagree but brands (like AGCO, Kubota, BMW, Ford) do specify quality of their sourced parts right? Seems like contractual specifications such as quality control levels, failure rates, materials used, design, etc would be common practice.
Therefore, even though Ford doesn't make the blinkers in my F250, I kinda consider them responsible for the blinkers' quality. And if all the electrical relays constantly failed on my Ford, that's going to reflect poorly on Ford's overall quality.
*Please note that I am not picking on Massey Ferguson. I think they make a great tractor. Just to general rambling thought. :drink:
   / Broken already! #34
   / Broken already! #35
   / Broken already! #36
The reality is that every tractor manufacturer has problems to one degree or another. The critical interface and main difference is the DEALER and my caps key is not stuck. By the way: I mechanically removed the caps lock key from my keyboard and have never been the least bit sorry.
chuckle....I did that on my last keyboard that wore out and got a new one but have not yet removed that darn key. I was determined to learn a way around that key but so far unsuccessful.
qq1..opps, just popped it out<smile......Nice to hear i am not the only one that has had problems with that key.
Back to deciding which small tractor to buy to compliment my bigger duo, an old 29 hp ford and a massey 40. Kinda leaning towards the massey 1526 or jd 1025r
   / Broken already! #37
Not familiar with the 1526, but, the 1025R will NOT replace the Ford 2000. Not even in the same league. :)
   / Broken already! #38
a lock out would be nice i agree
   / Broken already! #39
your right and no way i will replace my D2000 that is one outstanding tractor of which i am the second owner. I just thought a smaller tractor would be nice in tight places and my in my blueberry acerage. That 2000 has yet to be stopped. Equipped with a 1971 brush hog which still has the original rebel flag it goes right over blackberry thickets at least 8 feet tall and alder grooves of inch inch and a half thick a few feet tall, trees that grow like weeds on part of my land without slowing down. All that happens is they are sucked under the tractor and you hear the engine tone change but rpm stays rock steady and out the back flies small pices of alder or blackberry bushes. An amazing machine.
a small tractor with loader and backhoe would be handy putting in feeder irrigation lines and moving things in the barn among other things
1973 Ford 2000 1071 Brushhog. Pix taken last year by a friend after killing alders
   / Broken already! #40
Thanks for the pic. Looks like beautiful country.
UNUSED LANDHERO LDH-T460 STAND ON SKID STEER (A54756)
UNUSED LANDHERO...
2017 Ford Fusion Hybrid Sedan (A55758)
2017 Ford Fusion...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A54756)
PAIR OF DIAMOND...
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A55787)
2025 SDLL30 Mini...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
