Broke the new Deere
   / Broke the new Deere #121
Exactly what I was thinking. They seemed to do a rush job to fix the obvious problems and get it back to the customer, which some people would hail. However, did they do a thorough and proper inspection? Maybe not. Did they really diagnose what failed, or caused it to fail so as to avoid a repeat? Time will tell.
   / Broke the new Deere #122
Maybe they repaired a symptom and not found the problem yet.:)
   / Broke the new Deere #123
That would be my concern as well. I abuse the crap out of driveline in my hobby. I don't think a U-joint coming apart caused this breakdown. Time will tell.
Hoping for a positive outcome!!!!
   / Broke the new Deere #124
Dangit Murph, why didn't I just say that rather than my lengthy response......
   / Broke the new Deere #125
   / Broke the new Deere #127
I guess that it would have been better to let it set around for a couple of months like some dealers do, then tell the owner that there's nothing wrong with it. Or do like what happened when the front axle sheared off on a friend's 3 month old Montana; make him pay the two thousand dollar difference between what the manufacturer allowed for the repairs and what the dealer felt that it was worth.
i will say from my experience with cracked things - it all depends on the crack/metal, its a long time before you realize they are cracked, sometimes there is even rust internally on things before they fatigue enough to finally break, im glad this broke right away because chances are if it had not i might have had to pay for it later not knowing and just suspecting the cause - no one is perfect - my cousin has a 1206 Farmall, was hauling hay with it like he had done a hundered times before FOR YEARS, had just rand down the road hi speed turned into our old home place was going slow up the driveway and snap, rear axle broke, right inside the rear housing, rear wheel bent the fender in and pinned him in the seat and broke a couple ribs, the shaft looked like it has been cracked for years and finally came in two, it was rusty inside from moisture over the years before it finally broke - who knows how long it has been - that tractor has been ran hard for years, running duals, disking etc......i dont expect everyone and everything to be perfect and catch things 100% of the time, I know the mechanic and svc mgr well enough i feel comfortable in knowing they did their best. I never pressure them with a time frame I just let them work.
   / Broke the new Deere #129
The “rust “ in a fatigue failure like that is called fretting corrosion. It is caused by micro motion between two surfaces hat have partially separated in the fatigue zone.
Eventually the crack propagated to the point that there is a catastrophic failure and th parts (axle shaft in this case) separate.
Moisture had nothing to do with it.
hey finn, thats interesting to know, i am sure that axle had been flexing and moving for years before it finally broke like that we are so glad that it didnt happen when he was going do the road full speed when it snapped it could have been certain death for him = sometimes blessings come in peculiar packages
2010 Honda Accord Sedan (A55853)
2010 Honda Accord...
2016 JLG 20MVL 19ft Aerial Platform Lift (A55851)
2016 JLG 20MVL...
Wooden Rocking Chair (A55853)
Wooden Rocking...
1997 FORD F-SERIES DUMP TRUCK (A57192)
1997 FORD F-SERIES...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
