Broke caliper bleeder
   / Broke caliper bleeder #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I think the best way is to replace the caliper? It is 86 CJ7, calipers are original, rebuilt once in 99, I think new ones are in order anyway.
Better idea anybody?
   / Broke caliper bleeder #2
I've had broken bleeder valves and was able to get them out with an ez-out. There is already a hole in the broken one to use with the ez-out.
   / Broke caliper bleeder #3
Another option that sometimes works is to drive an allen wrench into the hole in the bleeder and use this to turn them out. Allen wrench isn't as hard and brittle as an EZ out. Use lots of penetrating oil and let it soak for awhile.
At that age new calipers may be a better choice.
Roy
I will definitely try to get it out, there is nothing to lose. Thanks, guys.
   / Broke caliper bleeder #5
Left handed drill bits work fairly well.
Nor-the-rn T**l has an assortment. I'm sure others do also.
Dave
   / Broke caliper bleeder #6
They also make repair kits for the bleeders, and oversizes, but as cheap as the rebuilt calipers are, a new pair would go on mine.
   / Broke caliper bleeder #7
Dave
LH drill bits work real well, the heat of drilling seems to help get the broken item moving...
   / Broke caliper bleeder #8
I've tried every penetrating oil and I have found Yield from chemsearch to be the best. We call it goat piss in the shop. It works!
That allen wrench sounded like a great idea, but this was apparently beyond fix. Will turn it in as core with part of the allen wrench:D
   / Broke caliper bleeder #10
the left over wrench will cost you . once you make it harder for the rebuilder they charge :(
2020 Kubota BX23S TLB Compact Tractor (RIDE AND DRIVE) (A50775)
2020 Kubota BX23S...
6' 3pt. Cultipacker (A50775)
6' 3pt...
2025 Auger Skid Steer Attachment (A55787)
2025 Auger Skid...
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
Paladin Excavator Mounting Plate (A50775)
Paladin Excavator...
Golf Cart (A55853)
Golf Cart (A55853)
