Broke caliper bleeder
   / Broke caliper bleeder
Picked my parts from autozone, checked them briefly and later realized the caliper is for passenger side - i.e. the bleeder is lower than brake line input.
To make he jeep driveable I stuck a piece of wood in the caliper, twisted the caliper to put the bleeder above the brake line and pushed the air out following the normal procedure. Than I mounted the caliper and pads and drove to town to finally get the driver side caliper. When it comes, I will swap the old one on the right side for the one currently on the left and install a new one on driver's side. It is a PITA, but I will do anything to keep the jeep running.
   / Broke caliper bleeder #12
the left over wrench will cost you . once you make it harder for the rebuilder they charge :(
Maybe but most of the time when I return a core they don't look at them very well, sometimes they don't even look in the box!
   / Broke caliper bleeder #15
Too late for your situation but this worked for me about a month ago when I had the same problem. I tried easyout and That didnt work. I took a washer with the inner diameter about the same size as the bleeder or a bit smaller. I welded the washer to the bleeder with my MIG. I then welded a nut to the washer. All the heat from welding helped break it free. It turned out of there no sweat after that!:D This was the first time I tried this trick, been wanting to try it for a while. Ok, well nobody wants to do things like this unless they have to but you know what I mean.:thumbsup:
Takeuchi TL10 (A57148)
TAG 18in Digging Tooth Bucket Excavator Attachment (A55973)
TAG 18in Digging...
2021 Deere 333G (A53317)
2021 Deere 333G...
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
2015 Jeep Cherokee 4X4 SUV (A56859)
2015 Jeep Cherokee...
1999-2010 Ford Pickup Truck Bed (A55973)
1999-2010 Ford...
