Broke 2 Oil filter wrenches
   / Broke 2 Oil filter wrenches #71
I just ordered one of these for the stuck on filters, though smaller than most tractor hydro filters. We'll see how it does.
Lisle 63600 Oil Filter Tool,​
Never seen one of those Lisles, but the design looks great - thanks for posting that. It brought back memories of our kitchen in the sixties. Mom had arthritis in her fingers, so jar lids could be a challenge for her. But in the top drawer, just under the counter, she kept her nuclear options:
The Edlund is what I first thought of when I saw the Lisle. Dual racks & single pinion running gear - for a six year old with an abnormal interest in gears it was hypnotic.
If the Edlund couldn't free up a lid, then out came the Foley, all chrome and killer hornet yellow. The Foley yielded to no jar. The leverage and resulting grip on a lid was deathly. In Mom's achy hands it shattered a full jar of spaghetti sauce. Like a firearm, it demanded respect. Playing around with it one day, its pinchy parts gave me a blood-blister the size of a penny. If you extended the jaws a bit, it just might make a decent end grabbing filter wrench.
I wonder if the designer of the Lilse grew up with an Edlund?
   / Broke 2 Oil filter wrenches #72
The biggest culprit that causes filter to "cook" onto the mount is the use of "used" oil on the gasket rather than using new oil, seconded by excessive overtightening during installation. Most filters call for up to 3/4 of a turn after the gasket ring makes contact. Seen this way too many times!!!
   / Broke 2 Oil filter wrenches #73
Those unitool wrenches suck . I bought one twenty some od years ago and never realy had success removing any filters with them. First the don't bite into the filter so unless the filter is big enough to take up the slack on the first few windings you have to hold the wrench and then turn it to take up the slack .Thats if there is enough room to get both hands in and be able to turn a wrench.
They only work on like 1 diameter filter, the rest were always too small or too large. When I get a new piece of equipment that has a odd ball size on it I usually just by the right cap type wrench . Over the years I have acquired. 20 - 30 different types of filter wrenches.
Strap wrench [oil filter] is #1 cap wrench #2 most used. 🍻
   / Broke 2 Oil filter wrenches #74
Before the 1970s or so, cars were designed to be serviced by the owner. My ‘49 Ford, every thing was easy to get to. Some cars today, you have to unbolt the engine mounts to change the spark plugs.
Anything on the front of the engine in a Volkswagen is: Step 1 remove bumper and grill
   / Broke 2 Oil filter wrenches #75
My idiot ex wife wanted a Saab. She thought they looked cool. It drove all right, could go like a bat out of hell.
I had to do the water pump.
To access the water pump, required I drop the tranny and lift the engine. Yah, for the water pump.
It would only accept one model of Continental tires ( the most expensive model).
I got rid of that car with the witch.
That's what happens when they install the engine backwards. Only good job on that car was a clutch replacement. It is done from the top side in a few minutes. Congrats on losing the witch.
   / Broke 2 Oil filter wrenches #76
This is a Factory one. Prolly put on with a pneumatic tool with the torque set too high. I'll be lucky if the thing wasn't cross-threaded on.
first change on my Kioti CK25. Had to punch a hole in the filter, of course ALL the fluid drained out!
   / Broke 2 Oil filter wrenches #77
Here is what you need; I have been there. This wrench will put pressure on the entire filter. After it tightens it will not slip because it grips the entire filter. Since it a coil you can take your had and compress the tool to get it on the filter.
I have never crushed a filter with this tool. In fact I used this tool to take a filter off that started to shred apart.
Do you have a name or source for that? Looks super cool if nothing else.
   / Broke 2 Oil filter wrenches #78
I had a thought...why don't I measure my Kubota oil filters before ordering the UNITOOL Coil Spring Type Filter Wrench?
So I did. Uh-oh....The coil spring says it is for 3" size filters. All of the Kubota filters are over that. Suction, HST, and engine oil all ranging from 3.6 to 3.725 inches.
rScotty
But it's a coil spring, why cant you just unwind it a bit for a larger size? Works in my head anyway.
   / Broke 2 Oil filter wrenches #80
Trying to get the Hydro oil filter off.
I am hoping to avoid pounding a hole through the thing because it'll be messy.
I've crushed the can with one tool A band wrench just slips. A chain wrench slips. Can't get my big pipe wrench on it; no room to maneuver.
I used a slip jaw filter wrench and it was a bear to get off. No need to be on that tight.
Cat 936 936F 938G Forks (A59213)
Cat 936 936F 938G...
2023 Deere 325G (A57148)
2023 Deere 325G...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2015 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A58214)
2015...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
