Broadcast Spreader Settings for Triazicide Acre+
/ Broadcast Spreader Settings for Triazicide Acre+ #1
Argonne
Paris, TX
JD2210, Ford 4400, Case IH 685, Terramite T7, JD 6x4 M-Gator
I know, this is a long shot, but I'm trying to save myself a few hours of experimentation.
I need to spread Spectricide Triazacide Acre+ at the .8LB/1000SqFt rate with my King Cutter 400 Poly 3 point spreader. Has anyone out there done this combination, and what gate setting/PTO speed/Ground Speed did you use. Commence crickets.
/ Broadcast Spreader Settings for Triazicide Acre+ #2
I don't have any hard details to help you, but I had to apply 40 lbs per acre of fertilizer on a pasture a couple weeks ago using a broadcast spreader. It was my first time so I had to make an educated guess.
I knew that a 5 gallon pale was about 40 lbs, I had 6 acres to cover, 6 buckets went in the hopper and I went out. I eyeballed the flow coming out of the hopper and in the end I had a little left over, so I did a couple passes in areas I thought needed a little more.
Worst case, start slow and see how fast the hopper goes down vs amount of ground covered.
UNUSED FUTURE PG72-72" HYD PLATE GRABBER (A60432)
UNUSED FUTURE...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
UNUSED FUTURE ELECTRIC WET POLISHER (A60430)
UNUSED FUTURE...
2 ROW CULTIVATOR W/PLANTER (A60430)
2 ROW CULTIVATOR...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A59230)
2016 Freightliner...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
