Broadcast Spreader Settings for Triazicide Acre+
   / Broadcast Spreader Settings for Triazicide Acre+ #1
Argonne
Paris, TX
JD2210, Ford 4400, Case IH 685, Terramite T7, JD 6x4 M-Gator
I know, this is a long shot, but I'm trying to save myself a few hours of experimentation.
I need to spread Spectricide Triazacide Acre+ at the .8LB/1000SqFt rate with my King Cutter 400 Poly 3 point spreader. Has anyone out there done this combination, and what gate setting/PTO speed/Ground Speed did you use. Commence crickets.
   / Broadcast Spreader Settings for Triazicide Acre+ #2
I don't have any hard details to help you, but I had to apply 40 lbs per acre of fertilizer on a pasture a couple weeks ago using a broadcast spreader. It was my first time so I had to make an educated guess.
I knew that a 5 gallon pale was about 40 lbs, I had 6 acres to cover, 6 buckets went in the hopper and I went out. I eyeballed the flow coming out of the hopper and in the end I had a little left over, so I did a couple passes in areas I thought needed a little more.
Worst case, start slow and see how fast the hopper goes down vs amount of ground covered.
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A57453)
2013 International...
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
1991 40ft. Trail King T/A Drop Deck Equipment Trailer (A55973)
1991 40ft. Trail...
Enmark Z Spray (A53316)
Enmark Z Spray...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
