Briggs Vanguard 23 in a Steiner 420
   / Briggs Vanguard 23 in a Steiner 420 #11
Hmmm, I'd have to look and see on the Briggs when you get the model. Regular Kohler CH were good to 25 degrees, I think. . . It is possible the Steiner group spec'd out a different pickup or something. Saw this on a larger model: Maximum angle of operation for the engines in the 450 Tractors: – Kubota D902: 20° continuous, 30° intermittent* – Kubota WG972-GL: 20° continuous, 30° intermittent* – Vanguard Model 61: 20° continuous, 30° intermittent* Your 23 would be like a 38" engine.
   / Briggs Vanguard 23 in a Steiner 420 #12
Here is the Vanguard 23hp manual
Check out page 10, right side column, half way down talks about 15 degree limit.
It doesn't mention serial numbers - so your mileage may vary :sneaky:
Thank you.
15 degrees? I'm getting the Steiner cause it can go up slopes (up to 58%!!!).
Now my choice is between this 420 w 23 HP Briggs, or a 430 Max with 25 HP Kohler. 430 max- about $1,200 more, is cleaner and has been serviced well by the dealer (new seat, new belts and new park brake).
   / Briggs Vanguard 23 in a Steiner 420 #14
Thank you.
Be careful not to mix units. I think you are referring to 58 percent slope which is equal to just a hair over 30 degree slope.
I'm already leaning towards the 430 Max cause it's cleaner anyway. But how much better can the stock Kohler be as far as the angle?
I won't go near 58% or 30 degrees. I'm near my limit w my 15 degrees driveway already. What worries me about inclines, is the switchbacks and saddle paths. It's one thing to go straight up and down and incline, whole different thing is crossing a slope.
   / Briggs Vanguard 23 in a Steiner 420 #16
I had a 430MAX with the Liquid Kubota Gas Engine for a little while. I don't like gassers, and still had to fart around with that stupid choke, but man, was that ever a sweet, smooth running engine.
You need to rethink that statement, My 4500P doesn't have a choke and it has higher horse power and more torque than the Kubota diesel and only burns .1 of a gallon more an hour...... jim
   / Briggs Vanguard 23 in a Steiner 420 #17
I would make sure on how steep the engine will work at. I had a air cooled stiener and it lost oil pressure were I cut.... jim
   / Briggs Vanguard 23 in a Steiner 420 #18
I think you have a manual for a vertical shaft engine
   / Briggs Vanguard 23 in a Steiner 420 #20
I guess it isn't worth messing with on less you would have flat ground...... jim
JLG 660SJ (A58214)
JLG 660SJ (A58214)
12ft 5in Flat Bed (A57453)
12ft 5in Flat Bed...
LOT: (18) Scraper Bars for Sakai Pad Roller (A59076)
LOT: (18) Scraper...
2003 Case-IH 586G (A57148)
2003 Case-IH 586G...
3500 5 LUG AXLE (A58376)
3500 5 LUG AXLE...
2015 Ford Explorer XLT 4X4 SUV (A56859)
2015 Ford Explorer...
