Breed Pipe
/ Breed Pipe #1
Nickak8
Marcellus, MI
1956 Massey Ferguson TO35 Branson 3515R
Hi all,
My Branson 3515R manual says to clean the breed pipe after 50 hours. I am not able to find in the manual or on the internet what the breed pipe is or how to clean. Any help is appreciated.
Thanks,
Nick
/ Breed Pipe #2
I was checking the service manual and I believe they meant the crankcase breather. Which sits on top of the valve cover with a hose straight to the intake manifold.
It has a filter inside that needs to be cleaned every once in a while.
The "breed pipe" is probably a typo which is quite common on Asian manuals that are translated to English.
/ Breed Pipe #3
I wonder if it is a engine BREATHER vent and the correct wording was lost in the translation?
edit: ptsg...you beat me to it.:laughing:
/ Breed Pipe
Awesome, thank you both for the quick reply.
/ Breed Pipe #5
Yes, I like to clean my breed pipe way more often than every 50 hours of use. :laughing:
/ Breed Pipe
Ok, so I removed the only hose I could find that went between valve cover and intake manifold. It was a 1” OD tube that had no filter in it. Looks clean. See pics. Let me know if you think it’s something different otherwise I’m gonna call it good.
2012 FORD F-550 CAB AND CHASSIS (A67714)
2012 FORD F-550...
525 GAL WATER TANK (A68842)
525 GAL WATER TANK...
2016 Kia Rio Sedan (A66738)
2016 Kia Rio Sedan...
HOSES (A68842)
HOSES (A68842)
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2020 Mack Anthem...
2018 FORD F-150 (A67714)
2018 FORD F-150...
