etpm
- Joined
- Jun 30, 2021
- Messages
- 2,407
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
The difference between oxy/fuel and oxy/acetylene is that the temperature of the oxy/acetylene is higher than oxy/fuel while the oxy/fuel delivers more heat. So even though oxy/acetylene has a hotter flame oxy/fuel has more heat. The oxy/fuel flame is not as concentrated as an oxy/acetylene flame. The upshot is that oxy/acetylene is great for welding steel because of the really hot and concentrated flame, while the oxy/fuel flame is better suited for brazing cost wise. Acetylene is expensive, while propane (fuel) is much less expensive. This is why oxy/propane is a major flame cutting setup. The oxy/propane heats the steel prior to the start of the cut, then the oxygen really starts to flow. Then the oxygen starts an exothermic reaction with the hot steel and the cutting commences. This process allows cutting steel more than 1 foot thick with minimal dross. So the oxy/fuel heats the beginning of the cut and then the pure oxygen starts to actually burn the steel. Of course you don't care about any of this, you just want to braze. Oxy/fuel brazing will be much easier that air/fuel brazing provided your torch is large enough. This is because our atmosphere is only about 20% oxygen. Pure oxygen allows a much hotter flame.
Eric
Eric
