Branson warranty troubles
/ Branson warranty troubles #1
BumpandNan
Hampton, Nova Scotia
Branson 3510H
Just wanting to know if many are or have had trouble with Branson standing behind their product?
Our 2013 3510H had stub axles break 3 times in 3 1/2 months. Also big creeping problems, also slower than it was.
We were fairly happy with this until dealer became aggressive and Branson refusing to even communicate re warranty.
Yes, we are still under warranty.
We are asking for our money back.
Just wondering if others have had difficulty with Branson warranty.
Thanks.
/ Branson warranty troubles #2
Is it 3 times in 3 1/2 months or is it 3 times in 7 months. I don't think there would be 2 owners with the same problem and comments on the internet. What are you doing when they break?
/ Branson warranty troubles #3
Branson has stood behind mine so far but no repeat failures like you are experiencing.
Same thing, 3 times in 3 1/2 months or its been 3 times in the last 7 months, whichever is correct. Same owner. Dealer replaces the axle. One only lasted a week. We are wanting a permanent fix since they say they are not responsible once the warranty runs out. They say no. Just wondering if others have issues with warranty that's all. Our mechanic said we weren't alone in relation to the stub axles breaking.
Whatever. It happened in a 3 1/2 month period, three times. However, the first instance was 7 months ago....that means.....the last time it happened was 3 1/2 months ago.
So....one can say it happened within a 3 1/2 month period
or
it happened in the last 7 months.
So sorry for any confusion. Seriously....the issue it that it happened and that it's a dangerous problem and that Branson won't take it seriously.
I'd really rather just stay focused on the issue.
Thanks.
/ Branson warranty troubles #7
I'm confused.
A search on google shows the complaint on other Branson youtube videos venting about broken stub shafts with different time lines. Anyway to the question I asked earlier. What tractor activity are you engaged in when the stub shafts have been breaking?
/ Branson warranty troubles #9
digging, driving and backing up
I predict it will be called abuse even though its normal activity for which the "tool" should be suitable.
... Can you show a pic of where the stub breaks? -- Theres usually a stress riser that is the root cause when you approach strength limits, as you apparently are. -- Sometimes removal of an extremely small amt of material will spread out the flexing area and prevent it cracking.
/ Branson warranty troubles #10
What kind of weight is on the tractor and what is recommended in the owners manual for using the FEL? Same wheel or the opposite wheel. My guess is that it is correct or a dealer would have jumped all over that one. Axles should never break on new tractors.
I had two axles break on a JD garden tractor many years ago but I was treating it like a bulldozer so I brushed it off. Come to find out they weren't heat treated properly, if I recall correctly. It wasn't under warranty so I just changed them and forgot about it.
2012 VANTAGE TRAILER PMEUMATIC CEMENT TRANSPORT TRAILER (A60736)
2012 VANTAGE...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
FUEL CELL (A58214)
FUEL CELL (A58214)
2017 PETERBILT PB337 HYDRA-TAIL FLATBED TRUCK (A59823)
2017 PETERBILT...
Great Dane Van Trailer 1989 (A61307)
Great Dane Van...
2010 Case 580N (A60462)
2010 Case 580N...
