Branson tractor 2400 front end loader
   / Branson tractor 2400 front end loader #1
Omatchen
Gadsden,Al
2014 Branson 2400
The hydraulics quick connect 2 of the 4 won't connect on the front end loader . I't the red&white connection.
I can move the green & yellow to red & white it's snaps on fine. I can move red&white to the green & yellow it will
Not snap
New tractor I'm not that familiar with hydraulics
   / Branson tractor 2400 front end loader #2
Make sure the connections are clean. They should all be the same.
I had to clean the connections on my pressure washer to get them together. They had surface rust on them.
   / Branson tractor 2400 front end loader #3
might have pressure on them, loosen the fittings a see if they have pressure then try to connect
Thanks for your suggestion I located the problem
Thanks for input that was the problem
   / Branson tractor 2400 front end loader #6
On my Branson I have to shut off the engine and run the remote controls through a cycle to get easy engagement. Agree on pressure on one or both sides will inhibit connection.
Mark
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
King Kutter 6' 3 pt Mower (A50515)
King Kutter 6' 3...
1275 (A50490)
1275 (A50490)
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
