BRANSON F4350 - HELP
/ BRANSON F4350 - HELP #1
PEM
Corrales, NM
Branson F4350
Would appreciate some help:
I purchased this tractor, new, in 2003-no problems until now. I let the fuel run out, after refilling the tank, the darn thing won't start. Engine turns, with plenty of power, fires slightly every once in awhile, but just does not start. The user manual is useless, bad grammer, small pictures too dark to see clearly. I have heard that in diesel engines the fuel line has to be bled, or the injection nozzle/s have to be cleaned or that the glow plug/s have to be replaced. I don't know anything about diesel engines, need step-by-step instructions. Anyone know where I can get a better manual, and an engine/mechanical manual?
Thanks
/ BRANSON F4350 - HELP #2
If your tractor has the electric fuel pump you should be able to turn the key on and it will purge itself.
For a manual fuel pump (fuel pump, Not injector pump) or electric you can crack (loosen the nut on the fuel line at each cylinder) each fuel line and crank until fuel comes out without bubbles. Best to do this one at a time starting with closest to the injector pump.
Make sure you didn't pick up any water in the bottom of the tank too. Water can stop up a fuel filter.
STIMW, thanks.
How do I deal with the water, if that's what happened?
/ BRANSON F4350 - HELP #4
Your filter should have a drain on the bottom. Always drain into something clear so you can inspect for signs of water. I use a 2 liter soda bottle with the top cut off. The fuel and water will seperate with the water at the bottom.
If you don't have a drain at the filter then remove the filter and dump it into bottle for inspection.
You can dump a filter and put it back on to get by but you need to change it ASAP. They get clogged and don't work as well when reused.
/ BRANSON F4350 - HELP #6
Hey all- just a thought. I would also put a small in line fuel filter before the electric fuel pump. The tolerances of my pump were so close that a small piece of debris caused it to stop running, and left me cold (even though I was thoroughly practicing against contamination. Also on my 3520, the factory fuel filter has a "pressed in" hose connector that frequently loosened. It looked like it was sealed with nail polish.
BUYERS PREMIUM & PAYMENT TERMS (A59914)
BUYERS PREMIUM &...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A63276)
2021 SANY SY265C...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
