Branson brand to be discontinued?
   / Branson brand to be discontinued? #152
Out of curiosity I just tried doing a search for Branson tractor dealers and website does not work. Tried doing same search on TYM and it also does not appear to show current Branson dealers. TYM site does seem to show Branson models as well as TYM so possible they are still working on getting all the Branson info transferred. No TYM with dealer shown with in 50 miles, Branson dealer is 4 miles away.
The dealer locator definitely has both on TYM site. In Texas, Caddo Mills (Big Tex) and Carthage (Anderson) are/were both Branson. Longview (RJ) and Tyler (Coker) are/were both TYM.
Not sure though on some things, RJ has two locations (Longview and Seagoville). Only the Longview location is on the TYM locator. RJ website still shows both as TYM.
   / Branson brand to be discontinued? #153
I would just like to have one in ND.
Please (hat in hands).
I drove the T494H today. Nice unit, what a tight turning radius! About 30F, as cold as my barn ever gets… Fired right up. I really liked the auto-throttle.
Dealer seemed very knowledgeable. Took a lot of time to offer information, learn my needs. The main salesman was at the dealer conference in FL where they are learning more about the integration of the Branson line… but they said at this time they DO NOT KNOW if they will ever see a Branson model on their lot, branded TYM or not. I asked about the 4820, and they said they have no idea if they will ever see a model previously produced by Branson.
Ive been interested in the LS tractors as well… but I’d really like to have the A series TYM diesel instead.
Does the 4820H have autothrottle or cruise control?
   / Branson brand to be discontinued? #156
Maybe it is different here. Tyler, TX is one of the Branson assembly locations. Oddly enough, there was no Branson dealer in Tyler until this merger. (unless maybe an older one went under?). Both local TYM dealers said it would be no problem.
Also, the Kioti/TYM/Branson dealer in Nashville,TN has both lines in stock. He's had TYM for about a year. Branson is just recent.
   / Branson brand to be discontinued? #157
Both.
The autothrottle in my 3725 is a simple cable attached to the HST linkage. It opens the throttle a fixed amount depending on HST pedal movement. It's enough when in middle range but in high range (I have the three speed range transmission) it's not enough and you have to bump the throttle up manually. High range is only useful for roading on flat roads, which don't really exist here. So it works ok for me.
Both.
Awesome, I really enjoyed the T494 auto throttle while playing on it at the dealer today. That motor is so quiet.
   / Branson brand to be discontinued? #159
I don't know if the Kukje engined TYMs use the same cable auto throttle. Looking at the specs it looks like they use different hydraulic pumps and transmissions. It might only be the engines and FI pumps they're using.
The Kukje A series four cylinder really is quiet though.
   / Branson brand to be discontinued? #160
TYM sight shows Agassiz sales in Buxton, ND as a dealer. Looks like close to MN border north of Fargo.
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2002 CATERPILALR D8R HI-TRACK CRAWLER DOZER (A52707)
2002 CATERPILALR...
2018 KENWORTH T880 DAYCAB (A55745)
2018 KENWORTH T880...
2020 Case-IH 250 Magnum (A53314)
2020 Case-IH 250...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52706)
2018 CATERPILLAR...
Kohler CK5-5H (A47477)
