Branson 4820 problems
/ Branson 4820 problems
I use an ORC on all our tractors to make life easy on the internal PTO brake.
More good information. I am learning. Thanks.
I will add, along with the hydraulic deadheading suggestions, check the parking brake. Make sure it's off and not stuck on or something. That's burning waaaay too much fuel for just a dead heading hydraulic system.
Well, I did adjust the knob below the seat and the rear lift is working again. Operator error! But I am unclear on the hydraulic deadheading, not knowing what that means. I have run old tractors without hydraulics for years but hydraulics are new to me and I am still learning. Please explain what you were talking about because I still have a reduced power issue and you may have the answer.
I would also check that your PTO is not in "Economy" mode. That can cause it to bog down in heavy grass.
It WAS in economy mode and this change helped but I still am having power issues. Thanks for the good advice.
/ Branson 4820 problems #34
Could you be clearer about reduced power? Before it was struggling with a 4’ mower. Is that still the case?
The hydraulic system in your tractor is know as open center system. This means the hydraulic pump pumps a constant amount of fluid through the system as long as the engine is running. As long as you are not moving a control valve like to raise or curl the loader, the fluid flows through the valve and back to the transmission known as the tank.
As you move a control valve, like raising the loader, the fluid is sent to the cylinder and pressure builds. As the pressure increases it will lift the loader.
If the cylinder on the loader is fully extended or if you open a valve like the remote with no cylinder, the pressure builds quickly to the point the pressure relief valve kicks open to provide a path for the oil to flow and protect the pump. This is hard on the pump as it is operating at near the pressure limit of the pump. We consider this as dead heading the pump. If it was not for the relief valve, hoses and lines would split and the pump likely would come apart under the high pressure.
This also would cause a loss in power because the pump is working at it’s max output. Also the hydraulic fluid temperature would rise as well.
Everything I described is a separate system from your HTS transmission. HTS uses the same fluid but has another pump that is controlled differently than the main hydraulic pump.
/ Branson 4820 problems #35
Now another question I have. You have three maybe 4 ranges for you HTS drive. If you have it in the higher range, the tractor will move faster with the pedal pressed all the way down but will require more power from the engine to do so. This could make it appear to have less power doing certain things.
Also many people think of the HST pedal like a gas pedal of a car. When the feel the tractor slow from lack of power, like climbing a hill, they push harder on the pedal. The proper thing to do would be press less on the pedal so the engine is not working as hard to move the tractor. Of course you also could pick a lower range to operate in as well.
I hope this helps but I suggest you get with your dealer for more training and to make sure there is nothing wrong with the tractor.
/ Branson 4820 problems #36
It's especially confusing on newer tractors which link the throttle to the HST pedal. Then the pedal is like the gas pedal in a car, and yet it's still also not like it at all.
Branson's system is a simple cable, unlike the computer controlled system on the Kubota Grand Ls. The amount of throttle movement is fixed relative to the HST pedal even though the higher ranges need more power. On my 3725 with three ranges, in low range the auto throttle works pretty well even on moderate slopes. In middle range which is what I use 95% of the time the auto throttle is sufficient on level ground but not if I'm doing any pulling or going up a moderately steep slope (15 degrees or more). In high range forget it, you need to use the hand throttle just to keep it from stalling on level ground.
If I'm doing PTO work or pulling anything heavy or using the loader or grapple I bump up the rpms with the hand throttle. For most PTO work I set the rpms to make the PTO turn 540, except for the forestry winch where that's a little faster than I want and I don't need much power.
Man, this is good stuff. Yes, it still is pulling the 4' mower. I will take it to the dealer and request a check of the hydraulic system. Thanks much!
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
2014 Nissan Juke SUV (A59231)
2014 Nissan Juke...
