Branson 4720h initial service / Issues and Concerns / Information Needed
   / Branson 4720h initial service / Issues and Concerns / Information Needed #21
what and where is a burp plug
   / Branson 4720h initial service / Issues and Concerns / Information Needed #22
I drained one side of front axle to replace oil seal . and added oil to just one side and it went to the other side also so apparently they share the same oil reserve . I messed up and use hyd 303 don't do it so now I have to redrain ans use proper oil which is Texaco or cheveron . someone recommended using dohn deere oil . not sure but I ordered a manual specifically for my tractor and will wait for it to come in before doing anything that's could hurt thr transmission
   / Branson 4720h initial service / Issues and Concerns / Information Needed #23
I did the same thing .
   / Branson 4720h initial service / Issues and Concerns / Information Needed #24
can the screen be cleaned or does it have to be replaced . I had a john deer 401b and the screen was metal and it could be cleaned .
   / Branson 4720h initial service / Issues and Concerns / Information Needed #25
I do not know on the 4720 but the 8050 is a metal screen which I clean and reuse.
I believe that I have seen somewhere that the front axle should be switched out to gear lube and not the hydraulic/transmission originally speced.
   / Branson 4720h initial service / Issues and Concerns / Information Needed #26
thank you but I ordered the service manual for the 4720h and should receive it soon . my tractor is a 2011 model and again I appreciate your answer. wow u have a big tractor.
   / Branson 4720h initial service / Issues and Concerns / Information Needed #27
Im pretty sure I read the same thing on the gear oil
   / Branson 4720h initial service / Issues and Concerns / Information Needed #28
There is no screen in my 2016 4720. I would like to ask if anyone knows of the front diff dipstick is suppose to be screwed in or not screwed in for checking fluid level?
   / Branson 4720h initial service / Issues and Concerns / Information Needed #29
Due to warranty, I can't do the service myself here in Portugal, so I had to go to the dealer. It's a small dealer so I was able to sit there and watch all the process. The mechanic checked the front diff fluid level with the dipstick not screwed. I don't think it would make any difference, it's just about 15 mm of thread and the fluid changes places all the time inside the diff.
   / Branson 4720h initial service / Issues and Concerns / Information Needed #30
Manual for my 2016 4520R says check front axle dipstick without threading in, just seated on top. Just did full service this weekend.
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
Ford 8340 (A53317)
Ford 8340 (A53317)
2000 Morbark Towable Brush Chipper (A59228)
2000 Morbark...
