Branson 4720h initial service / Issues and Concerns / Information Needed
   / Branson 4720h initial service / Issues and Concerns / Information Needed #21
what and where is a burp plug
   / Branson 4720h initial service / Issues and Concerns / Information Needed #22
I drained one side of front axle to replace oil seal . and added oil to just one side and it went to the other side also so apparently they share the same oil reserve . I messed up and use hyd 303 don't do it so now I have to redrain ans use proper oil which is Texaco or cheveron . someone recommended using dohn deere oil . not sure but I ordered a manual specifically for my tractor and will wait for it to come in before doing anything that's could hurt thr transmission
   / Branson 4720h initial service / Issues and Concerns / Information Needed #23
I did the same thing .
   / Branson 4720h initial service / Issues and Concerns / Information Needed #24
can the screen be cleaned or does it have to be replaced . I had a john deer 401b and the screen was metal and it could be cleaned .
   / Branson 4720h initial service / Issues and Concerns / Information Needed #25
I do not know on the 4720 but the 8050 is a metal screen which I clean and reuse.
I believe that I have seen somewhere that the front axle should be switched out to gear lube and not the hydraulic/transmission originally speced.
   / Branson 4720h initial service / Issues and Concerns / Information Needed #26
thank you but I ordered the service manual for the 4720h and should receive it soon . my tractor is a 2011 model and again I appreciate your answer. wow u have a big tractor.
   / Branson 4720h initial service / Issues and Concerns / Information Needed #27
Im pretty sure I read the same thing on the gear oil
   / Branson 4720h initial service / Issues and Concerns / Information Needed #28
There is no screen in my 2016 4720. I would like to ask if anyone knows of the front diff dipstick is suppose to be screwed in or not screwed in for checking fluid level?
   / Branson 4720h initial service / Issues and Concerns / Information Needed #29
Due to warranty, I can't do the service myself here in Portugal, so I had to go to the dealer. It's a small dealer so I was able to sit there and watch all the process. The mechanic checked the front diff fluid level with the dipstick not screwed. I don't think it would make any difference, it's just about 15 mm of thread and the fluid changes places all the time inside the diff.
   / Branson 4720h initial service / Issues and Concerns / Information Needed #30
Manual for my 2016 4520R says check front axle dipstick without threading in, just seated on top. Just did full service this weekend.
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
John Deere Gator (A53317)
John Deere Gator...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 Ford E-350 Enclosed Service Van (A59230)
2012 Ford E-350...
CAT 930M (A58214)
CAT 930M (A58214)
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
