Branson 4720 PTO problem
/ Branson 4720 PTO problem #1
MMG
Branson 4720
I have a seven year old 4720 with 700 hours. I just bought a five foot 3pt tiller and am having problems when engaging the ground. At first it was OK but after about 30 minutes the PTO shaft quit rotating when the tiller is lowered to engage the ground. It also makes a "ratcheting sound internally. I even loosened the clutch on the tiller to allow slippage if I hit something and not slip internally but it made no difference.
Any ideas?
/ Branson 4720 PTO problem #2
Check the other post; your's might be the same thing.
Yes Sir, I found the other string after I posted this one so I highjacked it.
:ashamed:
/ Branson 4720 PTO problem #4
These might help a little in your planning .......
/ Branson 4720 PTO problem #5
First I must say nice photos and I have to compliment the manufacturer on the case and the contents because that's quality manufacturing and machining there.
What I dont understand is why would hydraulic pressure effect those clutch disc's if they are held in compression by the tension of those springs. To me your photos appear to show a mechanical slip clutch within the shaft of the PTO; so why would hydraulic pump pressure effect those springs? It would seem to me that the amount of torque applied to the shaft via hydro motor dependent on hydro pressure would not effect something mechanical. Someone please help me.
2019 CATERPILLAR 259D3 SKID STEER (A62129)
2019 CATERPILLAR...
2022 Mercedes-Benz Sprinter 1500 Cargo Van (A61568)
2022 Mercedes-Benz...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2025 Pabreak Hydraulic Excavator Arm with Tooth Bucket Skid Steer Attachment (A61567)
2025 Pabreak...
2021 CATERPILLAR 300.9D MINI EXCAVATOR (A62129)
2021 CATERPILLAR...
