Branson 4720 PTO problem
/ Branson 4720 PTO problem #1
MMG
Branson 4720
I have a seven year old 4720 with 700 hours. I just bought a five foot 3pt tiller and am having problems when engaging the ground. At first it was OK but after about 30 minutes the PTO shaft quit rotating when the tiller is lowered to engage the ground. It also makes a "ratcheting sound internally. I even loosened the clutch on the tiller to allow slippage if I hit something and not slip internally but it made no difference.
Any ideas?
/ Branson 4720 PTO problem #2
Check the other post; your's might be the same thing.
Yes Sir, I found the other string after I posted this one so I highjacked it.
:ashamed:
/ Branson 4720 PTO problem #4
These might help a little in your planning .......
/ Branson 4720 PTO problem #5
First I must say nice photos and I have to compliment the manufacturer on the case and the contents because that's quality manufacturing and machining there.
What I dont understand is why would hydraulic pressure effect those clutch disc's if they are held in compression by the tension of those springs. To me your photos appear to show a mechanical slip clutch within the shaft of the PTO; so why would hydraulic pump pressure effect those springs? It would seem to me that the amount of torque applied to the shaft via hydro motor dependent on hydro pressure would not effect something mechanical. Someone please help me.
(250) Iranch Safety Traffic Cones (A60463)
(250) Iranch...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
Misc Office Tech (A59317)
Misc Office Tech...
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
TEST YOUR BID BUTTON! (A62130)
TEST YOUR BID...
