Branson 4520 hard to shift
/ Branson 4520 hard to shift #1
LuckyJack
Cherokee, Alabama
I test drove a Branson 4520 on Saturday and had a hard time shifting from one gear to the other. Stopped, clutch fully engaged. Just wouldn't easily drop out of gear. The salesman finally moved into the driver's seat to try after trying from the ground for a minute or so. He finally got it out of gear after a lot of easing on the clutch. Actually, there was some definite gear grinding when it finally popped out of gear.
I liked the tractor a lot, but wonder if this is common with new units...believe it had 5.5 hours on it. Or if this could be a problem specific to this unit.
Also wondered if it might be related to the issue noted in JonMark's post of 6/24.
Appreciate any thoughts.
/ Branson 4520 hard to shift #2
Perhaps this is one of the items that related to a lower price.
Egon
/ Branson 4520 hard to shift #3
LuckyJack
No, that is not common and there must be an issue with that tractor. In fact many dealers and customers have told me they shift better then many of the majors. Like any other tractor they are mechanical and built by people and although not often they can have a problem. They are an excellent product and I am confident you would be very happy with one. Did you ask the dealer about it? Maybe the clutch is out of adjustment.
Happy Tractoring
Chipperman /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
/ Branson 4520 hard to shift #4
Hey L-J,
Which shifter was stuck? The one to the drivers left is the range selector. It is not synchronized. Sometimes you have to ease out on the clutch just enough to move the tractor to get everything lined up. The one on the right is synchronized, smooth as silk.
Hope this helps.
Ken.
/ Branson 4520 hard to shift #6
I had some problems at first with my 3510, but with the shuttle shift going into forward. After a hour or so on the machine, everything has worked to perfection. Talked to 4 other Branson owners in the area (2810, (2) 3510s, and (1) 4520) -- none of them have had problems.
/ Branson 4520 hard to shift #7
that's the problem.
The range selector on the left is not synchronized, and you've got to stop.
The gear selector on the right is synchronized, and mine shifts smoothly.
Select the range, then feel free to shift around within it, but if you've got to change the range, stop the tractor.
anthony
/ Branson 4520 hard to shift #8
Mine shifts fine 3820, but sometimes you may need to
let the clutch out a bit and move it just a tad to get it to shift.
My tractor is 5 days old now, not a bad word to say
about it yet /forums/images/graemlins/cool.gif
Gene
Anthony,
Not being stopped was not the issue. I was fully stopped...as my original post says.
Luckyjack
/ Branson 4520 hard to shift #10
I have a Century 3045 and occasionally the range selector is difficult to disengage. What I found is while the tractor is running and the clutch is depressed, partially release the clutch and pull the range selector out of gear at the same time. This is an intermittent issue for me and doesn't seem to be any sort of real problem, more of an idiosyncrasy, I guess? (At least I hope /forums/images/graemlins/crazy.gif)
/ Branson 4520 hard to shift #11
I just noticed - GEB's method is probably the same as mine.
/ Branson 4520 hard to shift #12
Same here for me with the range selector on my Century 3035. A little clutch and it shifts. The gear shift has no problems.
/ Branson 4520 hard to shift #13
My range selector slides in and out like butter, I can even change gears sometimes while moving if I am fast enough.
The one I have to fight sometimes is the four wheel drive, both going into and outta four wheel drive. Like you guys said have to play with the clutch and move the tractor back and forth a little. Anybody elses hang up a little? Anybody found a sure fire trick yet?
/ Branson 4520 hard to shift #14
My range selector is the same as others. Sometimes I have let the tractor roll a bit or let out on the cluch just a little.
On the FWD what I have found to work the best is to just lift the front of the tractor to take it out of gear. I haven't had much trouble putting it into gear but taking it out don't even try anymore w/o lifting the front off the ground. I'd say this and the shuttle not working equally well depending on where the tilt column is are the two things that have bothered me the most so far. Maybe the shuttle has an adjustment somewhere? I haven't checked yet.
Oh, I have around 17 hours at this time.
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1996 Sunflower 1543-38 Folding Disk (A61307)
1996 Sunflower...
2016 Ford E-350 Passenger Bus (A61568)
2016 Ford E-350...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2018 Komatsu D61PX Crawler Tractor Dozer (A61567)
2018 Komatsu D61PX...
