Branson 4020 Fuel shut off on solenoid pull in
   / Branson 4020 Fuel shut off on solenoid pull in #1
RKH41
Branson 4020
Does this 2 coil solenoid have a relay between ignition switch & solenoid? Does the 70 amp relay on left side of firewall under dash control any part of the fuel solenoid function?
What is the function of the rectangular electrical box mounted on right side of firewall under dash? My fuel electrically solenoid pulls in ~25% of the time. It stays in once activated & shuts off normally. Ideas & suggestions welcome
   / Branson 4020 Fuel shut off on solenoid pull in #2
I have this exact same issue.
   / Branson 4020 Fuel shut off on solenoid pull in #3
Not knowing your equipment:
Some JD’s have a thermistor in the fuel pump circuit that does fail. Tractor cranks over but the injection pump is not activated.
   / Branson 4020 Fuel shut off on solenoid pull in #4
On my Branson 3510, the shutoff solenoid’s rubber boot was shot. It limited the movement of the shutoff solenoid, the plunger was extending too far. I used a couple of zip ties to limit the extension after researching and finding the cost of a new solenoid $$$.
   / Branson 4020 Fuel shut off on solenoid pull in #5
If you want a new solnoid get the spec's from the original and
search the net for a new one
willy
   / Branson 4020 Fuel shut off on solenoid pull in #6
From the 20 series manual;
  • Branson 20 series wiring part 1 pdf.pdf
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A52576)
2023 PETERBILT 579...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
