Branson 4020 Fuel shut off on solenoid pull in
   / Branson 4020 Fuel shut off on solenoid pull in #1
RKH41
Branson 4020
Does this 2 coil solenoid have a relay between ignition switch & solenoid? Does the 70 amp relay on left side of firewall under dash control any part of the fuel solenoid function?
What is the function of the rectangular electrical box mounted on right side of firewall under dash? My fuel electrically solenoid pulls in ~25% of the time. It stays in once activated & shuts off normally. Ideas & suggestions welcome
   / Branson 4020 Fuel shut off on solenoid pull in #2
I have this exact same issue.
   / Branson 4020 Fuel shut off on solenoid pull in #3
Not knowing your equipment:
Some JD’s have a thermistor in the fuel pump circuit that does fail. Tractor cranks over but the injection pump is not activated.
   / Branson 4020 Fuel shut off on solenoid pull in #4
On my Branson 3510, the shutoff solenoid’s rubber boot was shot. It limited the movement of the shutoff solenoid, the plunger was extending too far. I used a couple of zip ties to limit the extension after researching and finding the cost of a new solenoid $$$.
   / Branson 4020 Fuel shut off on solenoid pull in #5
If you want a new solnoid get the spec's from the original and
search the net for a new one
willy
   / Branson 4020 Fuel shut off on solenoid pull in #6
From the 20 series manual;
  • Branson 20 series wiring part 1 pdf.pdf
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
JOHN DEERE 3033R LOT NUMBER 225 (A53084)
JOHN DEERE 3033R...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
6ft LandPride Box Blade (A51573)
6ft LandPride Box...
