Branson 3510i
/ Branson 3510i #1
GWpal
Branson 3501 i
I have a Branson 3510i. While repairing some small leaks i disconnected the quick connects at the manifold for the bucket. I know I now have them in the wrong places, there are only 4 you would think that as many times as I have moved them by luck they would be right. I have bucket curl or up and down, never both. Thanks for any help I think I'm losing it I'm 77years old.
/ Branson 3510i #2
Follow the hoses from the lift cylinders back to the quick disconnects. These will plug into the two connections in line with a spool on the directional valve. Not sure which spool operates raise lower on machine though.
Curl dump would connect to the other two.
If function operates backwards just swap position of those two hoses.
/ Branson 3510i #3
After you get it sorted out, buy a bag of colored zip ties and mark each side of the quick connect. After that, it's just Red to Red, Blue to Blue, Yellow to Yellow and Green to Green. Or something similar. ;)
They're great for marking other things too. Keys, wire harnesses, etc.
  • Good Post
Reactions: MMC
Homemade Utility Trailer (A62613)
Homemade Utility...
1990 Wilderness Cimarron 29-5R Camper / 5th Wheel (A66285)
1990 Wilderness...
Hay Rake (A65640)
Hay Rake (A65640)
3 Brake Drums (A62613)
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
