Brand 5220ch overheated
   / Brand 5220ch overheated #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
How would you guys handle this. I purchased brand new 5220ch loader backhoe. Went dealer yesterday picked machine up. Get home take machine off trailer drive around and noticed the coolant Gauge in the red. Quickly turn machine of. Look over everthting can't find anything. The over flow tank was on the low side. I check the Radiator don't see fluid. In the end the machine holds 1.58 gallons antifreeze, I put a full gallon in to bring it to correct level. At this point how would you handle this. If it took that much , how do I know when they moved it from the plant to trucks it wasn't over heated? How to I know when they unloaded it at the dealer it wasn't over heated? Really upset but not sure what to do. Do I Demand a new machine? What will be the long terms problems. Any suggestions? Thanks
   / Brand 5220ch overheated #2
Real bad pre delivery inspection ...I would call them and make a big stink about it...You could have problems later ,Why was it low a leak ?.........
   / Brand 5220ch overheated #3
Definitely let the dealer know it took that much coolant to fill the radiator.
Monitor it closely to see if it goes down.
Did the dealer install a block heater or lower radiator hose heater before delivery?
How many hours on the tractor?
He did install the block heater. I spoke to him yesterday and he was the one that recommended checking the radiator. He blamed the factor. I just don’t know what to do. I’m worried I’ll have long term problems. After I filled it up it was fine no more over heating.
Also there was not leaks just radiator low on fluid. What do I need to watch for, if it did damage something?
   / Brand 5220ch overheated #6
There is your most likely answer, pulled the block plug installed the block heater and didn't refill the radiator, most of the coolant would drain out pulling the block plug.
Whoever he had doing the work screwed up, NOT the factory.
   / Brand 5220ch overheated #7
If he installed the block heater at his shop they did not fill the radiator back up plain and simple...........
   / Brand 5220ch overheated #8
Regardless of the block heater that tractor should have never made it from the dealership low of anything! Has nothing to do with the factory or assembly plant!
My suggestion is go over it thoroughly. Check oil, air filter, hydraulic fluid, hose clamps, grease everything and torque all the bolts you can access. Especially wheels and loader frame bolts.
Your dealer did not do a good job making the tractor ready for delivery. IMO
I agree K5iwq. At this point I don’t know what to do. How do I know I don’t have any kind of long term damage?
   / Brand 5220ch overheated #10
If you damaged anything it will show up quickly. Keep a close eye on your gauges and look for water in oil or white smoke out of exhaust. My bet is you will be ok, but time will tell. If it is going to be an issue it will happen while still under warranty.
20ft Bi-Parting Wrought Iron Gate (A51573)
20ft Bi-Parting...
UNUSED FUTURE FT13J EXCAVATOR (A51247)
UNUSED FUTURE...
UNUSED RAYTREE RPRB72-72" POWER RAKE BUCKET (A51248)
UNUSED RAYTREE...
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
