Brake master cylinder 1 or 2?
   / Brake master cylinder 1 or 2?
the parts manual has the pics, u must have a fel mounted to ur 5211, here is a couple pic that may help.
Thanks Mike the pics are a big help. I see the cover I am in the process of removing is already off in your pics.
Appreciate the info.
Neil
   / Brake master cylinder 1 or 2? #12
also drain and refill the steering box while its down.
Hi Mike, can you elaborate on draining the steering box for me, I am not sure what you mean. I am very proactive at preventative maintenance and look for any oppty to avoid issues and prevent wear and tear and this 5211 is new to me.
   / Brake master cylinder 1 or 2? #14
dont have a pic of the drain and fill points, but do have a pic of the strg box, its an integral part of the upper trans housing, 90 weight hear oil is
whats needed, if it gets water in it often then the input shaft seal is leaking, old timers would fill it with grease using a grease gun [ band aid repair ],
i rebuilt mine and filled with 90w.
the crossover tubes in the box are NLA.
   / Brake master cylinder 1 or 2? #15
the above pic is the right side, the drain and refill points is on the left side, the correct pic is below.
Adams 5T HC Spreader (A55301)
Adams 5T HC...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
3013 (A55851)
3013 (A55851)
2003 Nissan Xterra SUV (A55853)
2003 Nissan Xterra...
BOMAG BW75AD WALK BEHIND SMOOTH DBL DRUM ROLLER (A52707)
BOMAG BW75AD WALK...
