Brake controller ?
/ Brake controller ? #1
lizardman
Central SC
JD 850,JD 810A(mine),JD LX280(dad)
I am thinking of buying a new tandem trailer, and since brakes are required (and because I really need them), I want to know what name brand and/or model brake controller to get. I hope to get a Big Tex or PJ 16' trailer with ramps, but I havent talked with anyone yet.
My truck is a 2006 Toyota Tundra DC with only 7,000 lb tow capacity. (Probably my biggest reason to go with a 7k lb trailer!)
I currently haul a JD 850, usually with no implement but sometimes with a RFM, disc, or box blade. I am eyeing a tractor like a Kubota L3800 with FEL, but I dont know if that will happen b4 I am too old to need a tractor.lol
Your advice is greatly appreciated.
Rod
/ Brake controller ? #2
There are a number of brands. I personally have a Tekonsha (I think that is how it is spelled) and like it. The important thing, in my opinion, is to make sure that you get a PROPORTIONAL controller and not a timed one.
/ Brake controller ? #3
They are all about the same in the three price points. Under $100 is good for a guy who tows six or seven times a year. The $100 plus units are good for the guys towing that type of load once a month or so. In this price point its a good one is the Prodigy P3 for about $150 to your door. The best of the best is the Max Brake. It fully proportional and pressure drive. Its in the $300 range and need no adjusting once installed.
Chris
Responses...and you included price!!
Thanks for that tidbit of info. The mid-range one may do what I want, but I had no idea what the differences were between them. How does the Prodigy P3 work to make it better than the low end and worse than the high end?
I do like the non-adjusting" part of the higher $ one, though, as I am a sucker for things to be automatic and/or easy!!
A couple of years ago, I priced a trailer with brakes and the guy was going to set me up with a controller for about $200 more so I was figuring it to be in that price range.
If I get one from the trailer dealer, what name brand(other than what has been mentioned) should I look for in the Brake controller?
Thanks,
Rod
/ Brake controller ? #5
I am going to install a Max Brake Controller in the near future... I've ha a "parts store cheapo" in my truck for about 2 years... Every once awhile I get some pucker factor from it not deciding to work until the last minute..... that always sucks when you have 20K on the GN hitch!!!
/ Brake controller ? #6
I purchased a Tekonsha Prodigy 2 along with the correct adapter for my Ford F150. It plugged in and worked without my doing anything. I've been very pleased with it. Controller and wiring was around $120 shipped.
/ Brake controller ? #7
Prodigys are very good controllers, had them on all of my contractor dumps
Just by doing a quick search on ebay(yeah, I know), it looks like I can get a Tekonsha Prodigy P3 for as low as $125.
Would I be going wrong with that?
If it is recommended here, anyone know of a better price?
If the Prodigy P3 is pretty good or at least good enough, I cant see putting $300 in a Max Brake for the low amount of time/miles that I pull a trailer.
Rod
/ Brake controller ? #9
Rod
That is the price point I get them out. Its a good controller for the money. You can not get a better controller in my opinion till you get above the $200 price point.
Check with R&P Carriages. They have good prices, good people, and quick service. Many times I order in the morning and have it by Noon the next day via UPS or even plain old postal service.
R and P Carriages Trailer Sales, Service, Parts and Rentals
Chris
/ Brake controller ? #10
Rod
Tekonsha probably makes the most reliable that i have found.
/ Brake controller ? #12
i have drawtight activatorII's, as well as hoppy units in 3 of my trucks.
these are the 100$ units.
I have a sub 100$ hoppy that has the same features as the 100$ one with a more rudimentary digital display.
I also have a prodigy in one of my trucks.
bottom line? they all work and put power tot he brakes.
the prodigy is the nicest with a few extra features like boost.. etc.
the , arguably, cheapest of the bunch, the hoppy has made several multi state/multi-thousand mile trips with a 16' tandem big tex trailer to haul antiques back to my house.. nearry a problem with the controller.
soundguy
UNUSED ATSPOWER 40 GALLON AIR COMPRESSOR (A64281)
UNUSED ATSPOWER 40...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2013 29ft. Larson LXI292 Boat with 2007 30ft Loadmaster T/A Boat Trailer (A61574)
2013 29ft. Larson...
2015 Nissan Frontier 4x4 Crew Cab Pickup Truck (A61573)
2015 Nissan...
Caterpillar Articulated Truck Parts and Service Manuals (A63117)
Caterpillar...
