Brake controller ?
/ Brake controller ? #1
lizardman
Central SC
JD 850,JD 810A(mine),JD LX280(dad)
I am thinking of buying a new tandem trailer, and since brakes are required (and because I really need them), I want to know what name brand and/or model brake controller to get. I hope to get a Big Tex or PJ 16' trailer with ramps, but I havent talked with anyone yet.
My truck is a 2006 Toyota Tundra DC with only 7,000 lb tow capacity. (Probably my biggest reason to go with a 7k lb trailer!)
I currently haul a JD 850, usually with no implement but sometimes with a RFM, disc, or box blade. I am eyeing a tractor like a Kubota L3800 with FEL, but I dont know if that will happen b4 I am too old to need a tractor.lol
Your advice is greatly appreciated.
Rod
/ Brake controller ? #2
There are a number of brands. I personally have a Tekonsha (I think that is how it is spelled) and like it. The important thing, in my opinion, is to make sure that you get a PROPORTIONAL controller and not a timed one.
/ Brake controller ? #3
They are all about the same in the three price points. Under $100 is good for a guy who tows six or seven times a year. The $100 plus units are good for the guys towing that type of load once a month or so. In this price point its a good one is the Prodigy P3 for about $150 to your door. The best of the best is the Max Brake. It fully proportional and pressure drive. Its in the $300 range and need no adjusting once installed.
Chris
Responses...and you included price!!
Thanks for that tidbit of info. The mid-range one may do what I want, but I had no idea what the differences were between them. How does the Prodigy P3 work to make it better than the low end and worse than the high end?
I do like the non-adjusting" part of the higher $ one, though, as I am a sucker for things to be automatic and/or easy!!
A couple of years ago, I priced a trailer with brakes and the guy was going to set me up with a controller for about $200 more so I was figuring it to be in that price range.
If I get one from the trailer dealer, what name brand(other than what has been mentioned) should I look for in the Brake controller?
Thanks,
Rod
/ Brake controller ? #5
I am going to install a Max Brake Controller in the near future... I've ha a "parts store cheapo" in my truck for about 2 years... Every once awhile I get some pucker factor from it not deciding to work until the last minute..... that always sucks when you have 20K on the GN hitch!!!
/ Brake controller ? #6
I purchased a Tekonsha Prodigy 2 along with the correct adapter for my Ford F150. It plugged in and worked without my doing anything. I've been very pleased with it. Controller and wiring was around $120 shipped.
/ Brake controller ? #7
Prodigys are very good controllers, had them on all of my contractor dumps
Just by doing a quick search on ebay(yeah, I know), it looks like I can get a Tekonsha Prodigy P3 for as low as $125.
Would I be going wrong with that?
If it is recommended here, anyone know of a better price?
If the Prodigy P3 is pretty good or at least good enough, I cant see putting $300 in a Max Brake for the low amount of time/miles that I pull a trailer.
Rod
/ Brake controller ? #9
Rod
That is the price point I get them out. Its a good controller for the money. You can not get a better controller in my opinion till you get above the $200 price point.
Check with R&P Carriages. They have good prices, good people, and quick service. Many times I order in the morning and have it by Noon the next day via UPS or even plain old postal service.
R and P Carriages Trailer Sales, Service, Parts and Rentals
Chris
/ Brake controller ? #10
Rod
Tekonsha probably makes the most reliable that i have found.
/ Brake controller ? #12
i have drawtight activatorII's, as well as hoppy units in 3 of my trucks.
these are the 100$ units.
I have a sub 100$ hoppy that has the same features as the 100$ one with a more rudimentary digital display.
I also have a prodigy in one of my trucks.
bottom line? they all work and put power tot he brakes.
the prodigy is the nicest with a few extra features like boost.. etc.
the , arguably, cheapest of the bunch, the hoppy has made several multi state/multi-thousand mile trips with a 16' tandem big tex trailer to haul antiques back to my house.. nearry a problem with the controller.
soundguy
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TACTOR (A59912)
2019 INTERNATIONAL...
2014 John Deere 644K High Lift Articulated Wheel Loader (A61572)
2014 John Deere...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
