Brake Boot leak?
/ Brake Boot leak? #1
Scotty Dive
Ct
Yanmar 2020D
I was doing some maintenance on my 2020 - oil and filter, hydraulic filter an fluid change, fuel filter - when I noticed the boot to my brakes is seeping. What is behind here and is the boot just for protection? Just wanted to know before I called Hoye.
Also - looks like there is a drain plug on the rear of the front drive shaft. What does that drain?
/ Brake Boot leak? #2
/ Brake Boot leak?
I would think that there is an oring or some sort of seal behind the boot? Or is it the boot that holds back the fluid?
/ Brake Boot leak? #4
The boot is what holds the fluid. No o-ring. Boot just flexes as the brake rod goes in and out.
/ Brake Boot leak?
Just an update - replaced the boot - very easy job....probably best when doing an fluid change though.....lost about half a quart of fluid. Not sure if more would have come out, but I replaced the boot as fast as I could to minimize the mess.
/ Brake Boot leak? #6
I'm glad to know that Hoye has them in stock now. Mine in my 1802 started leaking about 8 years ago and I could not find one. I put a hot patch on it and it has held up so far but I always worry that it will start leaking again.
/ Brake Boot leak?
The boot came from Fredericks....I was looking for the hood emblems and Fredericks was the only place I could find them that said yanmar YM2020. Was tired of the tractor saying Zen noh and neighbors asking about it. ;)
/ Brake Boot leak? #8
My decals don't have the d either wouldn't mean anything to anybody but us I do understand your need for replacements however. I thought about having my graphics shop make me some but I sure intended to keep it a secret. :D
2018 ROCK SOLID CARGO 14 T/A SHOWER TRAILER (A65643)
2018 ROCK SOLID...
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
2021 YANMAR VIO35-6A EXCAVATOR (A63276)
2021 YANMAR...
1987 Asphalt Tanker Trailer (A65563)
1987 Asphalt...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
