Bradco pallet forks
/ Bradco pallet forks #2
They are skid steer forks which would require a converter as well as the forks (with the extra weight associated with the converter).
What price were you quoted for what size and weight?
Cliff
/ Bradco pallet forks #3
I don't know anything about Bradco, but I ended up buying Bobcat brand. For the quick attach pallet rack and 42" forks I think I paid around $600 new. I was going to do some deal on eBay for a no name setup, but that was only going to save me $50. I don't know what a JD setup costs, but the Bobcat setup was almost half of what the same thing from Kubota was going to cost me.
/ Bradco pallet forks #4
I am also interested in the JD (or other) pallet forks. How do you plan to attach the Bobcat forks to your 2305 (according to your profile)?
I have a 2520 with the 200CX loader, and I know that the attachments aren't going to match up.
According to the J.D. dealer and the Bradco website,
http://www.forddistributing.com/products/mfg_show.php/Bradco/35
they make forks that fit directly on to the J.D. loader. I've asked the dealer to get a quote and the weight and I will post that info. here when I get it.
I have also heard from HLA Pallet Forks,
http://www.horstwelding.com/hla_thumbs.php?sub=11
and they make a set that mounts to the loader for a list price of $605. They don't have any dealers in my immediate area, so there might be some freight, or a couple hours drive time.
/ Bradco pallet forks #6
I wonder if we got a group together and got orders for, say, 10 of them if we couldn't get a deal on them -- even if shipped to different places.
Or maybe with such an order in hand, Muhammad could get a special offer advertisement on TBN.
Cliff
/ Bradco pallet forks #7
I Have a set of JD forks with the head board that are quick change, I trade back and forth between the 4320 and the 2210. I only payed about $500.00 for them new from my dealer.
Jim
/ Bradco pallet forks #8
I did not care for the aftermarket ones not being able to answer the "how much will I be able to lift" question I asked them. I built my own and went to a local forktruck dealer to pick up a set of used 42" forks for $80.00 . I have a 4100 and I can pick 800lb 60" long load up from the ground to about 3 feet. 600lbs to about 4 feet and 500lbs to 5 feet. I bought an extra set of the quick attach lower pins and upper hooks when I bought my 200cx loader. The main problem with JD's and many of the other pallet fork attachment builders is that they build the thing way too heavy duty for the smaller tractors. You do not need a cage that can do 3000-4000lbs if the tractor cant do it anyway. All that the heavy set ups do is take directly away from the lifting capacity. JDs pallet fork attachment weighs in at a hefty 375lbs ..mine is 230lbs and cost under $200.00 in materials.
JD green paint $20.00
forks $80.00/pr (used)
steel for frame $50.00 or so
JD pins&hooks $35.00
I looks good too...not like some of the cobled homemade ones I have seen pics of.
/ Bradco pallet forks #9
I attached the pic on this one...the first time it did not work
/ Bradco pallet forks #10
davkir,
I'm not sure if you have checked out the Kasco pallet forks, but since you are located in Indy, you may want to since they are made in Shelbyville. I have a 42" set from them that are rated for 2200# (much more than my loader will pick up) and I like them very much. They are quick-attach style (skid-steer), but they also make them for your JD style loader. Here is the link Kasco Manufacturing I paid around $650 for mine. I purchased them threw my dealer, and picked them up myself from Kasco to save on shipping.
Just in case you are interested.
CBox /forums/images/graemlins/grin.gif
/ Bradco pallet forks #11
I did not care for the Kasco ones...much too bulky and the flat plate steel they are using as the back adapter plate makes it impossible to even guess where the tips of the forks are especially on a tractor that has the hood blocking the middle.
/ Bradco pallet forks #12
I have a set of Bradco pallet forks for my 2210 and they are fine forks if not a little heavy, and my nephew has a set bought at the same time he uses on his 4720 and he has lifted over 2000# with them so I know they are good for my 2210 they are quick disconnect made to fit JD and you just drop the bucket and hook the forks up it takes about 45 seconds. We bought them from Kevin at the Rushville John Deere Dealer, he is a great guy to deal with. they cost me $800 and I do recommend them. fort Wayne has them also.
good luck
Thanks for all of the great advice. I ended up with a set from Horst Welding (http://www.horstwelding.com)
They were about 60% of the cost of the ones from J.D. and they weigh about 160 lbs. less.
They fit my 200CX loader perfectly.
Another Pic.
2016 Isuzu NRR 18ft. Box Truck (A61573)
2016 Isuzu NRR...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2005 MACK CHN613 (A65643)
2005 MACK CHN613...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
Kenworth T6 (A63688)
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
