Backhoe Bradco Backhoe for Ford
/ Bradco Backhoe for Ford #1
jgbanshee
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
I have a Ford 345C tractor loader with a 26 GPM hydraulic pump to run the loader. I would like to carry that to the backhoe with a power beyond setup through the loader valve. My dealer tells me that the 26gpm flow is too much for a Bradco backhoe attachment. Is this true?
/ Bradco Backhoe for Ford #2
He maybe right, but you can put a flow restrictor in line with the supply pressure hose, and reduce the flow, and a wee-bit-o-pressure also. :D
Where can I find one of those? Will it reduce the flow and pressure to something reasonable to run the backhoe?
/ Bradco Backhoe for Ford #4
We have a old ford backhoe on a 1968 3000 ford but it is 11ft backhoe .The pump is a cesna i think but i dont know the gpm it's running.I would call bradco direct they have a good amount of knowlage on these set ups.The backhoe we have has pressure valve's on it you can adjust.
/ Bradco Backhoe for Ford #5
I'm not a hydraulic expert. But, I thought that the Power Beyond send ALL of the fluid that wasn't used to the next implement in line. If that is true, then you can't just plop in a restriction.
But, you can put an adjustable flow divider from the power beyond and split the flow between the backhoe and the return to tank from the loader.
Surplus Center - Hydraulic Equipment Electric Motors has them and pretty low $. Fer instance, Item 9-2597 would bleed off 7 1/2 gal to the tank and keep 19.5 gal going to the hoe. Might be about right? it's about $45.
jb
(15) Kinze 48 Cell Bean Plates (A65640)
(15) Kinze 48 Cell...
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
5.5x13 Homemade Trailer (A62613)
5.5x13 Homemade...
2015 Isuzu NPR HD Porta John Recovery & Cleaning Truck (A62613)
2015 Isuzu NPR HD...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
Can Am Defender (A63689)
Can Am Defender...
