Bracing fence corners with T-posts
   / Bracing fence corners with T-posts #1
quicksandfarmer
Elite Member
Coastal Rhode Island
Jinma 354, purchased 2007
Over the past ten years or so I've come up with a technique for creating rather strong braced corners with just T-posts as the part in the ground.
Here's a picture:
This fence is 54" field fence with a single strand of electric at the top. That's what I normally do for perimeter fencing, for interior fencing I often use electric rope.
I started down this journey when I realized that a piece of 1-1/2" PVC pipe fits snugly over a T-post. PVC pipe is the same outside diameter as the posts used for chain link fence. Chain link fences often just use pounded posts that are diagonally braced, so I started thinking if I could use chain link bracing with T-posts with a piece of PVC over them. The answer is yes.
I found it works better if you turn the bracing post 90 degrees so the spade is perpendicular to the direction of pull. The brace post is more stable if you take a 12" piece of treated 2x4 and drill a 1-5/8" hole in it:
Then slip that over the post so it sits between the spade and the PVC. Drive the post deep enough so the wood is resting on the surface:
What I like about these corners is I can install it with a post pounder and a wrench. They are pretty strong. I tension my field fence with a come-along. If I apply too much force the corner post will bend before it pulls out of the ground.
Over the years I've made some innovations. One is that instead of using chain link fence brace posts, I now use 10' pieces of 1-1/4" EMT. It's cheaper and I can get it at any big box store. It fits snugly inside 1-1/2" PVC, so I can make a corner where all of the pieces are clad in PVC pipe. When working with electric fence this means all of the pieces are insulated.
I use PVC electrical conduit rather than water pipe because it is more UV resistant, the white PVC tends to get brittle in the sunlight after a while.
If I don't need an insulated corner, I only need a few inches of PVC pipe to hook onto. If you drill a 3/32" hole in the pipe, and then put a piece of 12 gauge galvanized wire bent into an improvised cotter pin in the hole, it will hook onto a nub on the T-post and hold securely.
I use a 7/8" sheet metal screw into the cap and through the PVC and EMT to hold it together. But the force is all in compression.
I've also had good results bracing wood posts this way:
The fitting to attach a brace to a wooden post is called a "drop fork bracket," you can see it here:
   / Bracing fence corners with T-posts #5
I use Wedge-loc. They work well.
I've used Wedge-Loc, and I have to say I've had a very different experience. They're just not very strong, they're made of soft aluminum and bend under small amounts of force. They also have nothing to keep the brace post in, if there is any push in the opposite direction of the brace --like if you push on the corner -- the post just falls right out. They also require that the T-post be oriented just so because they can only go in one direction, and you can only do exactly 90-degree corners.
I got started down this path with Wedge-Loc and quickly found them to be not useful. I bought a box and ended up giving them all away. Corners made my way are far, far stronger. They can withstand hundreds of pounds of horizontal force.
   / Bracing fence corners with T-posts #7
I haven't had any problems with mine. Whatever works!
   / Bracing fence corners with T-posts #8
For my corners I use rock filled gabions. This one is made out of 4' x 8' warehouse shelving. Two shelves - folded in the middle - wired together - filled with rock. Calculated weight ~ 6500 pounds.
   / Bracing fence corners with T-posts #9
I do something similar, but I'm using 6inch x 8foot treated wood posts in concrete with 1 1/2 inch EMT for my bracing that is also set in concrete and attached with a 5 inch exterior structural screw.
The EMT comes in 10 foot lengths. I cut them in half at 45 degrees, drill a hole through the angle part of the EMT for the structural screw and anchor the other end in concrete.
I always bring the concrete up the post so water sheds away from it. In my experience, posts always rot at ground level, so keeping the water away from the base of the post will keep them from rotting.
My fencing is 4ft 2x4 horse fence. I like the wood posts because I can attach the fence to the posts with barbed staples, that make it very secure.
   / Bracing fence corners with T-posts #10
Agree completely. I tried a couple of corner braces with Wedge-Loc and found that in loamy or sandy soil, the corner T-post pulled out.
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
