Boxblade Usefulness Survey
/ Boxblade Usefulness Survey #101
Doc,
I think from your description that you have T&T for the 3PH. Although some question the usefulness of the T&T (and some just the tilt part), I think that this one enhancement makes all the difference in the world. Probably more so because of the tilt.
When you backdrag a FEL, the best you can do is level, with reference to the wheels of the tractor. However, with a tilt control and a boxblade, you can actually change the angle or slope of what you are working on. This is critical when doing things like grading a road or driveway, because you need to create a crown to allow the driveway/road to shed water. If all you could do was level, then you would have very little control of the shape. Well, you could, but would take a long, long time to accomplish it.
/ Boxblade Usefulness Survey #102
<font color=blue>I will probably break down and put in the hydraulics for top-n-tilt by the spring time. After getting on and off to make adjustments...</font color=blue>
I'm definitely happy with my top-n-tilt, but I have to admit, I probably learned to use the boxblade faster by not having it... it forced me to think through my adjustments and what their consequences would be (or face the prospect of even more trips up and down off the tractor). I COULD have gotten the same results without TNT, it just would have been a longer, more tiring process.
John
/ Boxblade Usefulness Survey #103
<font color=blue>difference between a regular box blade and a rollover boxblade</font color=blue>
I think there are some other folks on the forum who can do better job of describing them, but basically, a regular box blade is a fixed, rigid box with the front blade angled forward and the rear blade angled back. The scarifiers or rippers can be raised or lowered, one at a time manually on most (although they are also made with scarfiers that can be raised or lowered hydraulically). The roll over blade has a lever at the top and by pulling the lever, you let it "roll over" to whichever one of the three uses you want; scarifiers, forward tilted blade, or backward tilted blade. They're not the best pictures in the world, but you might look at some at <A target="_blank" HREF=http://www.bushhog.com>http://www.bushhog.com</A>, click on "Commercial and Landscape", then on the type of blade you want to see. Roll over blades usually cost considerably more.
/ Boxblade Usefulness Survey #104
Mike,
No I just reach back and move it manually. Yes I think that the T&T would be a nice feature and save time no doubt. I can do the same thing by manually moving the top link or the three point arm. My scarifers also have three positions that I can manually move them to.
/ Boxblade Usefulness Survey #105
Glennmac,
Hmm, I have to agree with what Trescrowes, Glueguy, and Cowboydoc have to say. My boxblade is second in utility only to my FEL. Of course I currently own only two implements for my 2910!/w3tcompact/icons/wink.gif
Here's what I've been able to accomplish with my boxblade recently:
1) Smoothed out my entire drive <font color=red>without</font color=red> top-n-tilt./w3tcompact/icons/shocked.gif Yes, I know it sounds impossible, but it's true.
2) Completed landscaping the entrance to my drive by using the rippers and backblading with the FEL. Looks great.
3) Converted a brushy area to lawn. The rippers tore out all of the <font color=blue>small</font color=blue> stumps and roots and by backblading with the FEL, a smooth surface resulted.
4) Ripped up a large flat area with the rippers. The topsoil will be removed with the FEL, and a gravel pad will take it's place. Hopefully a pole barn will magically appear, but that's probably too much to ask of the boxblade.
5) Successfully "tilled" the garden with thee rippers to a nice consistency. Ready to plant.
This was all accomplished with a $288 box blade. I could probably use a little more weight, but since I've never had it, I don't miss it (kind of like top-n-tilt). I know that a tiller would be more usefull for the garden, and a landscape rake might work better for making a lawn, but a boxblade's versatility can only be beat by an FEL, in my opinion.
/ Boxblade Usefulness Survey #106
This sounds like a boxblade could be used as a 'poorman's tiller'. True?
/ Boxblade Usefulness Survey #107
Very true Mike. Mine has 6 tines on it and works really well.
Well, I see that the 10 members of TBN who have mastered boxblading have come to the vigorous self-defense of of their investments.....I also defend my Mustang convertible as a useful hauling vehicle mainly because it is the only one I own......Obviously I am getting outnumbered here because the silent TBN majority of vegetarian liberal Democrats is again remaining silent.....I find it interesting that boxblades continue to spark the most controversy and frustration of any implement by far on this forum...controversy that is only matched by the political and hunting threads........All seriousness aside, it is clear that many find boxblades useful implements .... more so in parts of the country, or on land, that has non-bouldery soil that is amenable to scarifying and fluid movement.
/ Boxblade Usefulness Survey #109
<font color=blue>more so in parts of the country, or on land, that has non-bouldery soil that is amenable to scarifying and fluid movement</font color=blue>
Don't know what the "boxblade factor" is, but our land is boulder-y, and you have to get those outa there before the boxblade works well. On Sunday I was working our "lower flat", creating an area where we want to install a pergola, but it wasn't flat. I originally tried to dig it out with the FEL, but that was a loser because of all the rock and boulders. Then I tried to scrape it out with the boxblade. That didn't work either because I couldn't "square off" the corners and get all the way back, although it work better than the boxblade.
So I borrowed a neighbors "dig-it". ALthough it is a puny gas-engined back-hoe, it could at least get into the corners, and alllowed me to break up the rocks and boulders (or pull them out). I then went back with the boxblade, and pulled all the material out, and started to spread it out. Once I had that out, I loaded the (several tons) of big rocks into the FEL and hauled them away. Then I went back with the boxblade and smoothed the rest out.
When my wife saw what I had done, she just said: "Wow!".
/ Boxblade Usefulness Survey #110
Yes, you can plow/till with the tines down. This is, I have found, easier now with position control but it worked OK on the BX also. Yes, the box is a poor man's tiller. No--now don't get carried away and think it replaces a tiller but if it is all you got then it can do the job of tilling but more time and effort will be required, course compared to a shovel it is light years ahead.
The 10 non vegetarian, coffee drink'n, non liberal non democrats, non-PC have spoken and even Glueguy, a Californian, agrees /w3tcompact/icons/shocked.gif /w3tcompact/icons/wink.gif .
Nope Glenemac, the thing that stirs more controversy than the box and hunting threads is anything comparing a BX to a whatever or is a "BX any good" threads. The most recent probably, I fear, cost us RPM and the one before Woodstock, I hope not but I think that is what he meant when he said "logging off"--I really hope that is not the case.
/ Boxblade Usefulness Survey #111
<font color=blue>The 10 non vegetarian, coffee drink'n, non liberal non democrats, non-PC have spoken and even Glueguy, a Californian, agrees</font color=blue>
Well, I am only semi-vegitarian, I drink coffee, I consider myself semi-liberal and semi-conservative (depending on the topic), and non democrat, and non-republican, and non libertarian, and non green, and am a Californian. But I still agree on this one.
/ Boxblade Usefulness Survey #112
<font color=blue>I fear, cost us RPM and the one before Woodstock</font color=blue>
Woodstock posted on 1/25/2002 and RPM posted on 1/26/2002 so they're still around. /w3tcompact/icons/smile.gif
I dont know if its more mind-warping to read TBN everyday or episodically. Having been episodic recently, I now find that the High Priest of the BX Cult also has a 2410. Aha, creeping gigantism is at work..... By the way, I am neither a vegetarian nor a liberal Democrat. I'm a carnivorous conservative/libertarian, but I am opposed to hunting. That reference was merely my multitalented way of commenting on my long held belief that there are liberal Democrats on this forum who, however, hold their tongues on political threads because of the apparent overwhelming conservative tilt here.
/ Boxblade Usefulness Survey #114
Glenn,
Just curious as to the opposition to hunting?
/ Boxblade Usefulness Survey #115
Well this thread has probably run it's course till the next boxblade question is asked.
Yes Glenemac, I bought a 2410 to augment by BX. Why--why not? Also I have enjoyed comparing them and look forward to more comparisons when mowing season comes about. Lot's of things to do this Summer and Spring.
Yes, I am probably going to be excommunicated but seeing as how the two worthiest contenders for the crown of BX High Priest have both likely quit the forum (no involvement of mine) the cult will have no choice but to allow me to continue /w3tcompact/icons/shocked.gif .
I hope those two guys are still around because I liked them. /w3tcompact/icons/sad.gif
J
/ Boxblade Usefulness Survey #116
<font color=blue>don't think I've ever even heard of a manual for a box blade</font color=blue>
Well, Bird, I now have the ***official*** Howse Box Blade Operator's Manual right here in my hot little hands. /w3tcompact/icons/grin.gif
I also have a paper napkin here which contains about the same amount of useful information. /w3tcompact/icons/tongue.gif
I will file this manual in the same place I keep the rest of my tractor documentation for now, but if I ever run out of space, this will be the first thing I toss. It is so blatently useless that it's almost amusing for that very fact. My four-year old son can't really write yet, but he could document circles around this thing in terms of valuable content. My good nature and respect for the works of others prevent me from saying what I really think about this manual.
Just to ease your curiosity, let me describe the "contents" of this literary masterpiece:
- The vast majority of the 24-page "manual" is devoted to safety precautions. At a glance, these complex "machines", as they call them, can apparently fly apart and/or burst into flames! /w3tcompact/icons/shocked.gif
- There are two distinctly different versions of the box available -- "solid" (fixed rear blade) and "hinged" (the floppy kind), and they show side-by-side pictures to prove it. In the entire remainder of the "manual", there isn't a single word, not even a whisper about the hinged blade.
- "Dual scraper blades on the rear allow the unit to be used in the pull or push modes." That is the beginning, middle and end of the narrative on the blades.
- Instructions for attaching the "machine" (the box blade) to the tractor, Step One: "Lift the machine and slide the balls over the mounting pins." Apparently you lift the box blade with one hand and manipulate the lift arms with the other. I need to spend more time at the gym.
- From that last instruction, I got curious about the actual weight of the thing, so I flipped to the "specifications" section. Hmmm... the weight isn't specified. Nor are the dimensions. Nor the number of rippers for the different models. Guess I have the wrong idea about what "specifications" means.
- The "Field Operation" instructions are basically, "set it flat on the ground" and "go slow".
Not sure what I was expecting, but I'm pretty sure this "manual" falls short. /w3tcompact/icons/laugh.gif
/ Boxblade Usefulness Survey #117
/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
Harv, the literary quality of your manual is shamed by your own critique of same. Keep us laughing /w3tcompact/icons/smile.gif
/ Boxblade Usefulness Survey #119
/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gifI'll bet there's a reason I've never seen a manual for a box blade./w3tcompact/icons/laugh.gif I just got through looking at Bush Hog's web site, and their box blade manual is only 12 pages (for $4), except when you pull it up, looks like pages 10 & 11 are missing./w3tcompact/icons/laugh.gif At least it does list the weight in the specifications, and a whole chart of bolt torque values.
/ Boxblade Usefulness Survey #120
Have you ever seen one of those science programs where they have a room full of monkeys and they toss in a colorful interesting piece of fluff and then sit back and film what ingenious things they attempt to do with it and all the monkey interations?
Consider that the boxblade is not a "satanic" device but instead alien inspired. They tossed the monkeys a colorful bit of fluff and are now sitting back watching the show---whooop--whooop--eeeeccchhhhh--chhh (other chimp noises insert here).
Yep, an IQ test, and Glenemac failed. /w3tcompact/icons/shocked.gif .
I am just kidding Glenemac /w3tcompact/icons/smile.gif .
J
