BOX SCRAPER
/ BOX SCRAPER #1
Brimfield
Mass
Kubota L 3800
Next spring I want to get a Box scraper. What size is good for a L3800? I want one to make a lawn, right now its rocks timothy and wild roses etc. Was going to do it this fall but I was afraid of the frost hitting soon, oh well I guess not.
/ BOX SCRAPER #3
My b-i-l bought an L3800 last winter and got a blade for it. I believe his is 60" and it covers the wheels nicely, but not much more than that.
/ BOX SCRAPER #4
Five feet is the correct width. Buy the heaviest Box Blade you can afford. 600 - 700 pounds would be my recommendation for the rocky soil in Mass.
As you have a Backhoe, perhaps you can get by with a Ratchet Rake on the FEL bucket ($350) rather than a Box Blade, which will require you to remove the Backhoe.
Photo #1 is my Bush Hog (brand) Rollover Box Blade, 587 pounds. Photos #2, #3, #4 are the Ratchet Rake.
RATCHET RAKE LINK:
http://www.tractorbynet.com/forums/search.php?searchid=708746
/ BOX SCRAPER #5
I would go with a 66'' or 72'' for a L3800. The heavier it is the better it will work.
/ BOX SCRAPER
RATCHET RAKE LINK:
Nice box balde you got there. Ratchet rakes look good but I have high and low spots all over so I thnk I will stay witha box blade. I have never had the backhoe off yet but I gotta do it some day. Always threatening to drop it a d go in the woods for fire wood.
/ BOX SCRAPER #7
I just got a roll over box blade. Its the Bush Hog - 72" wide. Its just a little narrower than the rear tires (tires - 80,, robb - 72) but I'm finding it to be one of the handiest implements I own. I find the scarifiers do a great job of cutting thru the thick sod here and open my small garden plots without the need for moldboard plowing. I go directly from the scarifiers to the disk plow.
/ BOX SCRAPER #8
When I went looking for a box blade earlier this year for my B3200 (I'm also in MA) - I took everybody's recommendations into account : look for something heavy, get the correct width, a rollover blade is good - or get retractable rippers - etc.
After looking around for quite some time - and looking seriously at the rollover blades - I ended up deciding to get something with retractable rippers. Problem was - I couldn't find anybody that made one in the appropriate size for my B3200. Then I came across Cammond. So I ended up getting a 60" blade from them - with hydraulically retractable rippers. They even painted it orange for me to match the tractor.
If I remember correctly - the one I got was from the 2C1 series. You can go up to a 2C2 if you think you need something with more weight. They were great to deal with and shipped it out by truck freight. I just had to go down to the terminal and pick it up. All in all - no more hassle than buying from a dealer.
Back to Photo Gallery
If you're ever interested in taking a look - let me know.
/ BOX SCRAPER #9
FYI, I did all this with a York rake (with wheels)... Found on CL for under $500. Just a thought
/ BOX SCRAPER #10
My L3200 is the same as your L3800, just 6 less HP. I'm liking my 500lbs 72" King Kutter box blade.
I'd have loved something heavier and/or a rollover box blade, but this was the best bang for the buck. I may still end up strapping a railroad tie or 2 ontop of it for more weight. It takes a pass or 2 on the packed gravel driveway to start getting past the ripper teeth & filling the box. It's marginal in the dirt without the rippers, but pretty good with em down.
/ BOX SCRAPER #11
I ended up getting a 66" 2C2 for our L3240. 66" is just right for this tractor - not very many this size on the market.
The mechanical scarifier mechanism makes raising & lowering the shanks very quick. Very rugged and well built.
Cammond was great to deal with, but their shipper was a complete Charlie Foxtrot.
Lowe Quick Attach 1650 Classic Hydraulic Auger Drill & Bit (A66285)
Lowe Quick Attach...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
2006 Toyota Tacoma (A66408)
2006 Toyota Tacoma...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
