BOX SCRAPER
/ BOX SCRAPER #1
Brimfield
Mass
Kubota L 3800
Next spring I want to get a Box scraper. What size is good for a L3800? I want one to make a lawn, right now its rocks timothy and wild roses etc. Was going to do it this fall but I was afraid of the frost hitting soon, oh well I guess not.
/ BOX SCRAPER #3
My b-i-l bought an L3800 last winter and got a blade for it. I believe his is 60" and it covers the wheels nicely, but not much more than that.
/ BOX SCRAPER #4
Five feet is the correct width. Buy the heaviest Box Blade you can afford. 600 - 700 pounds would be my recommendation for the rocky soil in Mass.
As you have a Backhoe, perhaps you can get by with a Ratchet Rake on the FEL bucket ($350) rather than a Box Blade, which will require you to remove the Backhoe.
Photo #1 is my Bush Hog (brand) Rollover Box Blade, 587 pounds. Photos #2, #3, #4 are the Ratchet Rake.
RATCHET RAKE LINK:
http://www.tractorbynet.com/forums/search.php?searchid=708746
/ BOX SCRAPER #5
I would go with a 66'' or 72'' for a L3800. The heavier it is the better it will work.
/ BOX SCRAPER
RATCHET RAKE LINK:
Nice box balde you got there. Ratchet rakes look good but I have high and low spots all over so I thnk I will stay witha box blade. I have never had the backhoe off yet but I gotta do it some day. Always threatening to drop it a d go in the woods for fire wood.
/ BOX SCRAPER #7
I just got a roll over box blade. Its the Bush Hog - 72" wide. Its just a little narrower than the rear tires (tires - 80,, robb - 72) but I'm finding it to be one of the handiest implements I own. I find the scarifiers do a great job of cutting thru the thick sod here and open my small garden plots without the need for moldboard plowing. I go directly from the scarifiers to the disk plow.
/ BOX SCRAPER #8
When I went looking for a box blade earlier this year for my B3200 (I'm also in MA) - I took everybody's recommendations into account : look for something heavy, get the correct width, a rollover blade is good - or get retractable rippers - etc.
After looking around for quite some time - and looking seriously at the rollover blades - I ended up deciding to get something with retractable rippers. Problem was - I couldn't find anybody that made one in the appropriate size for my B3200. Then I came across Cammond. So I ended up getting a 60" blade from them - with hydraulically retractable rippers. They even painted it orange for me to match the tractor.
If I remember correctly - the one I got was from the 2C1 series. You can go up to a 2C2 if you think you need something with more weight. They were great to deal with and shipped it out by truck freight. I just had to go down to the terminal and pick it up. All in all - no more hassle than buying from a dealer.
Back to Photo Gallery
If you're ever interested in taking a look - let me know.
/ BOX SCRAPER #9
FYI, I did all this with a York rake (with wheels)... Found on CL for under $500. Just a thought
/ BOX SCRAPER #10
My L3200 is the same as your L3800, just 6 less HP. I'm liking my 500lbs 72" King Kutter box blade.
I'd have loved something heavier and/or a rollover box blade, but this was the best bang for the buck. I may still end up strapping a railroad tie or 2 ontop of it for more weight. It takes a pass or 2 on the packed gravel driveway to start getting past the ripper teeth & filling the box. It's marginal in the dirt without the rippers, but pretty good with em down.
/ BOX SCRAPER #11
I ended up getting a 66" 2C2 for our L3240. 66" is just right for this tractor - not very many this size on the market.
The mechanical scarifier mechanism makes raising & lowering the shanks very quick. Very rugged and well built.
Cammond was great to deal with, but their shipper was a complete Charlie Foxtrot.
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
20ft Jumper Cables (A65583)
20ft Jumper Cables...
2007 Hooper 20ft Equipment Trailer (A65563)
2007 Hooper 20ft...
Ford 3 Point Bucket Scoop (A62613)
Ford 3 Point...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
